Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 08-09-2004, 09:04 AM
tlee tlee is offline
Window Problem
I have a 96 Passat and the drivers power window won't go up all the way without some help. It gets to within an inch of the top and starts making a chattering sound. Any ideas? Do I need to replace the regulator?
Old 08-19-2004, 09:49 AM
jason_sabrina jason_sabrina is offline
Re: Window Problem
I have a Passat and mine has the same problem... there are teeth that run the window regulator and a couple of teeth are worn on it and it will cause a stuttering sound, then when you put it up all the way, hit the button it will go the rest of the way and hold it there... I hope this helps.
Old 08-31-2004, 05:17 PM
Rammstein Rammstein is offline
I also have a 96 TDI and I had to change my driver side window regulator.
I got a used one in good shape from Vortex and did it myself.
It's not that hard, all you need is a philips head screw driver and a 10 mm socket.
Different and efficient by choice!
Old 09-05-2004, 08:15 PM
Re: Window Problem
Thanks so much for your help on the window problem. I bought a new regulator on the web for $84.00 and installed it in about forty five minutes.
