Old 08-09-2004, 01:34 AM
dsilver101 dsilver101 is offline
plz help - weird starting issue
I have 650 holley double pmp carb on my chevelle and usually lately when I start it up it take a couple pumps to get it going, but when its hot, sometimes I have to hold the gas down for a couple seconds to get it going, then it revs super high then drops back down- whats going on? i know the idle speed cant be too low cuz its like 8-900 right now. I'm about to readjust that lower , but I'm thinking something else is going on here too.
second question- what is done to retune a carb for use with no choke? Does it start differently?
thnx- Dave
Old 08-09-2004, 02:18 AM
TechX's Avatar
TechX TechX is offline
hmmm it could be alittle rich. I always try many different ways to start my vehicles so I can make them pop right off. You might want to try others sequences. Like put the pedal to the floor, hit the dash, rub the steering wheel, then turn the key.
Old 08-10-2004, 09:20 PM
just needed a little carb tune, i think the ignition was a little more advanced than usual too-
i'm still wondering how someone tunes the carb different for no choke, I've noticed that i can start it with no choke if i just give it a tiny bit of gas for maybe 5-15 seconds, is this standard? -thanks
Old 08-11-2004, 11:22 PM
TechX's Avatar
When I drove a vehicle with no choke I started it with 1 or 2 gas pedal pumps before starting. Then to keep it running for the first minute I tapped the pedal alot. Enought to push the pump but not too much as to open the butterflies alot. About an inch is how far I would push the pedal down then let up and rapidly repeat. Yeah retarding timing can help a vehicle start also.
Old 08-18-2004, 03:43 AM
Cryo boy Cryo boy is offline
Send a message via AIM to Cryo boy
Re: plz help - weird starting issue
Umm, vehicals without choke (in my experence) suk. My daily driver (88 suzuki samurai) doesn't have a choke, it suks i have to babysit it for like the first minute to make sure it stays running. Mabey i have the carb out of tune, but id say that iif there is going to be any cold weather, to leave the choke.
Old 08-18-2004, 09:05 AM
i live in san diego, so it never really gets cold , so leaving it off doesnt bother me too much. Plus its only a weekend vehicle i drive for fun, so its all out performance, I'm probably just going to get a bigger carb main body with no air horn anyway. - Dave
Old 08-18-2004, 11:03 PM
firebird69racer firebird69racer is offline
dsilver101
What year chevelle you have, I live in San Bernardino
Old 08-19-2004, 11:10 PM
65 malibu ss clone - 454, turbo 400, 4:11 rears
I'll be hitting up carlsbad raceway next weekend for the first time, to see what my ride's really got.
I got some photo's to post but seem to be having trouble getting them in the message. It cant be that hard right?
Old 08-19-2004, 11:20 PM
There's a couple pics in my member gallery- Dave
Old 08-19-2004, 11:27 PM
thought Carlsbad closed down last week
Wade
Old 08-19-2004, 11:51 PM
you're right, i never heard about it till now, just saw the site- thats pretty sad..
i guess there' having drags on friday and sat at qualcomm stadium here in sd . Alot closer to home actually- I guess I'll be there then- unless they tear it down - Later
Old 08-22-2004, 08:42 PM
yz85guy yz85guy is offline
hey dude,try adjusting the float,it sounds like it may be a little too high .take a wrench&screwdriver ,loosen the screw while holding nut with wrench ,after loosening turn nut clockwise 1 turn,this should be enough to take care of it being too high.[being too high will let fuel leakinto intake after turning engine off,causing it to flood]
Old 08-23-2004, 08:25 AM
yeah, I did that when I did my full carb tune and everythings cool now. starts up as soon as i turn the key-
