Old 08-09-2004, 01:20 AM
kewlgye kewlgye is offline
Angry Brakes too close too floor!!!
Okay guys,
This has been talked about before. I've got a 98' z71 k1500. The brake pedal travels way too close to the floor for comfort, sometimes all the way. I've tried everything most can think of. On top of bleeding the system, the right way, about 15 times, I've replaced the master cylinder, front brake lines, pads, and rotors. I took it to a shop and had them bleed them, but no luck. They did however have a scan computer for the ABS system. They ran a bunch of tests on that $1000.00 ABS module, and everything works perfect, including all of the motors in it. The last thing the guy did, was run a self bleed with that scan/computer tool. After he did that, I got a very little bit of my pedal back.
I then went to the dealer and talked to the head tech. He said I had air stuck inside of my ABS brake module, and the only way to bleed it is for them to hook the truck up to their computer, and bleed it a certain way. He said there are a bunch of motors and valves in that module that have to be in a certain position in order for it to be bled.
Do you think that sounds right??? Any other ideas????
Old 08-09-2004, 01:40 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
Re: Brakes too close too floor!!!
try throwin some stainless steel lines from www.tirerack.com that brought my friends 1994 blazer k1500 from the floor to half way....see if that helps because not only will it help performance whise for your braking itll improve pressure and etc so try that....and btw my moms is havin the same problem im gunna throw some stainless steel lines on hers soon and ill see if that helps any or not..??..??..and if ya get it fixed anytime soon let us know
Old 08-09-2004, 02:12 PM
haleybarb haleybarb is offline
yah, i kinda get the same thing. new pads, one new caliper (drivers), replaced rear shoes, bled lines....a lot, watching the master cyl...had a mech adjust brakes for me cause i thought i mnusta done sumthin wrong...but i still get more pedal travel than i would like and i get the abs kicking in very easily...seems touchy....in places that you wouldn't expect abs to kick in.... wtf????
Old 08-15-2004, 03:08 PM
a coupla days ago replaced the badly worn out rear brakes and found that the wheel cylinders were pooched. couldn't take care of it then (i did the repair after my 12 hour shift at work....NAPA was already closed....), had them replaced the next day at a shop.....pedal travel was the best its ever been! and the ABS doesn't act up like it used to.....
so have your wheel cylinders checked? notice any uneven, excessive shoe wear?? not sure if that's any indication but it's a thought....i'm learnin' as i'm going....
