Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-08-2004, 11:45 PM
zaemaz zaemaz is offline
Send a message via AIM to zaemaz
Question cost of a repair?
does anyone know about how much it would cost to repair a possible oil leak in the valve cover? im pretty sure this is my problem but of course will get opinion from mechanic
Old 08-08-2004, 11:59 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: cost of a repair?
I don't think it should cost over $100. However, some valve covers are a bitch to get to and would cost more.
Old 08-10-2004, 10:42 AM
Bmaintz Bmaintz is offline
If you have the 2.2 (4 cyl) it is a easy job... Gently pull out the plug wires, take off the 4 large nuts, gentlt tap side of cover to dislodge & lift off.... You can use some permatex #2 to hold new gasket in place when installing... I think that $100 is a little high for a 15 minute job...
Bob
South Mississippi
92 & 94 Camrys
Old 08-10-2004, 10:49 AM
gator2764 gator2764 is offline
If it is a 2.2 with a few miles on it you might want to replace the Dist. O-ring also. They tend to get brittle and leak. Hard to tell if it is leaking because it drains down the back of the motor and drips about dead center. The rubber grometts around the spark plugs are easy to replace while you have the valve cover off.
Old 08-10-2004, 02:35 PM
Indetrucks's Avatar
Indetrucks Indetrucks is offline
I think he was reffered to a dealers cost at $100.00. In fact they will charge 1 hour at $75 an hour (depending on the labor rate) and $12 for the gasket and maybe $3.99 for the brake cleaner (parts wash) your looking at around $90-100. Yes it can be done by yourself.. Not difficult at all on the four cylinders...
Christian
62 Nova Pro Street BB
64 Lincoln Continental
65 Chevelle SS BB
72/01 Mini Cooper (Classic)
02 Ducati 998 Mono SuperBike
[I want you to remember that no bastard ever won a war by dying for his country. He won it by making the other poor dumb bastard die for his country…]
