Oil in the exhaust
When i start my rig up its a 91 s10 blazer 4.3 engine the exhaust is dark black and it shoots an oily residue onto the pavement. you can scrape it up with your thumb. It also has an excessive amount of smoke. It can be warmed up to normal temp of 210 and it still smokes like this when idling. I replaced the tailpipe a month ago it was broke off but the problem persists. I am going to replace pvc valve and o2 sensor but i dont have any ideas. Is it possible the head gasket might be going is gone? Let me know if you have any ideas. Thanks
Re: Oil in the exhaust
Wow, uh, no idea dude, that sucks.
s10BLAZERMAN:
probably isnīt oil at your tail pipe, could be and mixture carbon, water (cat residual) and gas not burned, i found a severous leak inside the injector camber (plenum) in my 4.3L W CPI, the hose line it was ripped, and i found an hole that connect this camber to a middle pistons ( 3 and 4), you can check this sparks plugs, then check for leaks above. Good luck |
im gonna replace the pcv valve and my o2 sensors first before i do that hoping maybe that will work but i dont have no check lights
You are running extremely rich by the sounds of it.
Is the smoke black or blue? |
I have an 88 blazer with a 350 .I have the same problem but not even close to being that bad and it only does it sometimes. .It only really does it when I start it up
white and billowy but black first and thats on the pavement i could post a pic of it smoke and pavement markings
Re: Re: Oil in the exhaust
BUT, does this white and billowy smoke continue all the time? Even when it is completely warmed up and you drive it? |
for about 5 minutes after ward to it is put in drive
Definitely too much fuel.
1995 Factory Blazer Service Manual for sale, PM if interested. |
where did this come from about the tuneup and what not?I had have plugs and a fuel filter pcv valve put on it.I run quiet smooth no idle problems no stalling problems runs really great just an oil leak
1991 Chevy S-10 Blazer 5.7 V8 RIP 1999 Chevy Blazer 2dr 4.3 |
im kinda confused because i have this threads link in the other thread
