Old 08-08-2004, 08:42 PM
Kujo Kujo is offline
my 94 chevy blazer s-10 misses after i changed my spark plugs and wires
Old 08-09-2004, 09:28 AM
JParrott's Avatar
JParrott JParrott is offline
Re: my 94 chevy blazer s-10 misses after i changed my spark plugs and wires
First off, elminate the obvious. You have the plug wires in the right order on the distributor cap going to the correct plugs? Then did you buy the correct plugs (heat range, etc.)? Are they installed properly, (i.e. tightness and not crossthreaded)? Is the distributor cap on tight? If all of this is correct, then it's time for some in-depth troubleshooting. Let us know what happens.
Old 08-09-2004, 08:14 PM
champion69 champion69 is offline
Just a reminder, ignition order for a 4.3L W, CFI is 1,6,5,4,3,2 clockwise, being post #1 straight to front and driver side; or pointing 5 to 6 hours, if you see the distributor in front your truck, (even the most experimented tech forget obvious), its a good idea check time positión 0 deg. Good luck
