Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 08-08-2004, 04:10 PM
nv300ex nv300ex is offline
Dodge Dynasty shuts off - need help asap
i have a 1991 dodge dynasty 3.3 engine, auto transmission, it cranks and everything goes smoothly like it should until i get like 4 miles down the road and it cuts off - just like you flip a light switch... - after it shuts off you can wait a couple minutes and it'll start and run all over again... I checked fuses, relays, and even put a new coil pack on it.. it still does the same thing.. any help would be appreciated... please help
Old 08-26-2004, 01:47 AM
bob bob bob bob is offline
Did you ever find out what was causing this problem with your dynasty?
Old 10-19-2004, 12:36 AM
trinityriver trinityriver is offline
Re: Dodge Dynasty shuts off - need help asap
I have the same problem. Someone is telling me that my CAM Sensor needs replacing. Does this sound right?
Old 10-26-2004, 10:09 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
That sounds accurate. Did the check engine light come on at any time?
Old 11-02-2004, 08:04 PM
93CivicLx's Avatar
93CivicLx 93CivicLx is offline
http://www.collegehumor.com/?movie_id=75357
i have respect for this dodge.
"H to the izzO N to the D A"
-Spell CiviC backwards- It's all great from front to back-
My car proflie http://www.cardomain.com/id/intoxicivicated
Old 02-24-2005, 03:11 AM
MyIonU MyIonU is offline
93 dodge dynasty doin the same thing. it is very annoying to feel your car is crapping out on you every day on the way to and from work... Luckily after about 1-15 minutes it starts right back up, hmmm. I do the error codes and get 11 12 forget and 55. I have had to replace the starter now 2 times due to this problem. I was told it is everything from the cam position sensor to the crank somethingorother. Does anyone know the fix for this clearly global problem, hehe..... db
Old 02-24-2005, 08:11 AM
code 11 is your cam sensor; have that checked out and replaced.
Old 04-12-2005, 02:38 AM
Prof.Factor Prof.Factor is offline
I have a Dynasty doing exactly the same thing. Only mine hasn't dropped any codes yet. Was wondering if you guys found the problem or if it was indeed the cam sensor. I will look at mine again this weekend. Very frustrating.
-Prof.Factor
Old 06-13-2005, 02:16 AM
Just to let you guys know .... stretched timing chain was the culprit with my 3.3 (115k). Code 11 never dropped because it only drops during start mode and not run mode.
FYI, you can check slop in the chain by dropping the oil pan. My chain had almost an inch of side-to-side slop which translated to over an 1/8 inch sprocket rotation play. New chain has very little slop and virtually no sprocket play.
-Prof.Factor
Old 09-25-2005, 11:51 AM
dynoman10 dynoman10 is offline
I have just about the same problem on my 89 3.0L Dynasty, no codes, fires right up and runs fine for a min. Then acts like it is losing fuel presure, everything checks out fine, has anyone found a cure for this?
Old 11-08-2005, 05:34 PM
holdemjunkie holdemjunkie is offline
Banned
Hey guess what???..I'm having the same stupid problem to, and I havent got a stright answer from any 1???,.,.Has any 1 figured this problem out, 3.3ltr on a 90 dynasty, im about to drive it off a cliff "if it would make it there" but its my girlfriends car so I cant....errrrrrrrr
Old 11-13-2005, 09:00 PM
Debralw Debralw is offline
Send a message via Yahoo to Debralw
I need your help I have a 1989 Dodge Dynasty
& where it says volts a red light comes on saying
check gages what does that mean. Debra
Old 11-14-2005, 06:01 AM
Banned
That light means that system has low voltage, prob ur alternator is dying on u. Get this looked at right away because it will leave u stuck on the side of the road. is it near stalling or stalling on u??
Old 11-14-2005, 06:04 AM
Banned
I finaly figured out the prob with my dynasty, I changed the coilpack, crank sensor, nothing happened, changed the cam sensor ran like a dream
Old 03-15-2007, 10:50 AM
hickabilly hickabilly is offline
Post Re: Dodge Dynasty shuts off - need help asap
I have a 90 Dynasty 3.0 and I went and still going through the same thing of spitting and hasitating, but I'm dune now with my car it's going in as a trade in or for sell, but I have put so much money in my car that I'm sick of fooling with it and I can basicly tell ya'll that it's either going to be your Oxygen Senser(s) or it's going to be your Fuel Pressure Regulator. If ya'll can do it your self do so, don't take it to a shop they will charge out the ying-yangto do all that it it's not hard to do your self.
