Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-08-2004, 03:55 PM
jvizal jvizal is offline
93 cutless ciera engine problem..please help
i have a 1993 olds cutless ceira s 3.3v6 wouldnt run, i had no fuel at the rail changed the fuel pump, and now i have fuel and spark but it wont run. when i unplug the maf it idles, but when i plug it in it dies..i replaced the maf sensor 150$ later, same thing please help
Old 09-30-2004, 09:22 PM
djnoname djnoname is offline
Re: 93 cutless ciera engine problem..please help
check your firing order on your plugs
rear plugs 2 4 6
frnt plugs 1 3 5
coil packs:
firewall
1
4
5
2
3
6
If that is not it you probably have a bare wire touching metal somewhere its not supposed to be and may need to have it tested. Would have to be electrical cuz you changed everthing else. Dont unplug your maf sensor to much this will foul your plugs.
