Old 08-08-2004, 12:45 PM
drummerboy8683 drummerboy8683 is offline
Send a message via AIM to drummerboy8683
New rims?!?!
I just oredered some 18" Mach1 rims for my v6 mustang. I will be replacing the 16" stock rims. My question is: will this conversion screw up my speedometer and odometer? if so, what can i do about it?
Thanks
Old 08-08-2004, 07:50 PM
augustorm augustorm is offline
Re: New rims?!?!
Thanks
I went to the Ford Racing FR500 18" Wheels from my 16" and Ford told me the that the difference depended on the size of tire....then they showed me the reason via their fitting software.
Right now (if stock) you should be running around a 225/55/16 tire.
The 18" rims are going to increase your outside wheel diameter by two inches...BUT if you reduce the side wall of the 18" tires by, say, going to a 35 or 40 series tire from the tall 55, the overall outside diameter will be about the same (you gain size from the wheel but loose size on the tire) so they offset each other. And the lower profile tire corner better...less sidewall flex...but a little bumpier ride.
Hope that helped.
'03 Stang V-6: Bored/Stroked(4.2L), Forged Crank, Wiseco Pistons, I-beam Rods, Crower Cam, Port/Pol Heads & Intakes, Radius valve job, Titanium valve springs, Ram air, NX wet (100 shot), Fluidyne radiator, JBA headers, Mac H-pipe, Borla side exit, Aluminum Shaft, Steeda race T-56, Truloc, 3:73 gears, Triax shifter. Tubular K-member, Steeda C/C plates, Steeda strut tower brace, Ken Brown shock tower brace, Steeda G-trac bar, Subframe connectors, Steeda 5-link, Eibach Prokit, Tokico Illuminas.
