Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-08-2004, 01:34 PM
old geezer old geezer is offline
Is Premium gas really needed?
Hi all,
I just purchased a 1997 Nissan Maxima SE and have read lots of talk about using premium gas. So, is premium gas really needed or is it just a preference. What kinds of symptons should I look out for if I use the regular 87 Unleaded gas? I'v'e had the car for 1 week and am getting ready to gas her up, so I'm trying to get a feel as to what gas I should use.
Thanks in advance
Old Geezer
Old 08-08-2004, 06:40 PM
THT THT is offline
Re: Is Premium gas really needed?
Yes, it is necessary. Engines like the VQ30DE that powers the Maxima are high compression engines; the Air/Fuel mixture is compressed to 11 atmospheres in the firing chamber before it's detonated by the spark plug, IIRC.
If you'll recall back to high school chemistry, when you compress a gas, it becomes more volatile and combusts at lower temperatures. This is important because the more your compress the A/F mixture in the firing chamber, the easier it is for the radiant heat from the engine block to detonate the mixture. This is problematic because it drives the piston down before it (and the crankshaft) are ready. This is knock.
Premium gas is of a higher octane than regular gas. Contrary to popular belief, higher octane does not always result in better performance (from a horsepower standpoint). Octane retards ignition so higher octane fuels require more heat to detonate, thereby lowering the chances of predetonation. That's why people who are running nitrous oxide or forced induction run 93+ octane fuel.
The onboard computer can do nothing to overcome the lack of octane besides retard the timing advance. On the Maxima, if the knock sensor trips, the ECU automatically retards the timing and you lose 20% of total power throughout the entire RPM range. I'd rather pay the extra dime per gallon and get the full potential of the car, even if I'm always cruising at 2,000rpms.
If the knock sensor trips, your car will be sluggish, especially when you floor it. Run the premium, it's worth it in the long run.
~THT
Some people call it an obsession; I call it my Maxima.
Old 08-08-2004, 08:34 PM
TeHsU TeHsU is offline
Send a message via ICQ to TeHsU Send a message via AIM to TeHsU Send a message via MSN to TeHsU
thanx dude, i was putting in 87, and my transmission was making noises, when i put it in drive, you could hear it change, i put 93 in, and no more noises
Old 08-08-2004, 09:12 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
Re: Re: Is Premium gas really needed?
~THT
I don't recall back to highschool anything. lol
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 08-08-2004, 10:21 PM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
does that apply for the older maximas?? cuz i've been runnin 87 octane n im juss curious
Old 08-08-2004, 10:29 PM
THT THT is offline
The principles apply however, older engines such as the VG have different compression levels. If the ratio is lower, you can run lower octane fuel.
~THT
Old 08-09-2004, 12:34 PM
Thanks THT!
I went ahead and put in the new Shell V-Power gasoline. I figured it will be approx $3 more to fill up my tank.
Old 08-09-2004, 10:59 PM
THT THT is offline
And believe me, it'll be worth it. Good choice!
~THT
Old 08-10-2004, 03:25 AM
ogparjay ogparjay is offline
i only put plus cause i can't afford getting supreme all the time.
Old 08-10-2004, 08:35 AM
gregory1041's Avatar
gregory1041 gregory1041 is offline
What would happen if I put 100 octane fuel in my 97 Max? I haven't done it, but was curious as to what it would do. The engine is stock.
Old 08-10-2004, 09:10 AM
95maxsewv 95maxsewv is offline
I have been putting that V power in from shell.. Car seems to like it... I think I have used both 94 octane and 93 from shell.. is that possible?
Old 08-10-2004, 11:10 AM
THT THT is offline
100 octane would result in less chance of predetonation, nothing else.
~THT
Old 08-10-2004, 01:26 PM
vinceleto vinceleto is offline
THT
It sounds like you know what your talking about, that was a great eplination of regular to premium. Is there a actual knock or ping noise that you would hear? I've used regular some times just to see if it would shut of my SEL. For some reason it has, "the code that autozone pulled was something about the CAT Po420 I think" Anyway when I use regular I notice that if I am light on the gas and approach a hill etc. the engine hesitates with a ping type of noise. But if I'm on the gas I never have a problem the car runs fine Regular or Premium. My only concern is whether this can cause future problems like a bad oxygen sensor or something like that. I would appreciate your input.
Old 08-10-2004, 01:32 PM
THT THT is offline
Yep, when there's knock, you'll here a metallic "ping" sound. Our knock sensors have a crystal piezo element (I think that's what it's called...) that is tuned to respond to that specific sound frequency so the ECU knows when knock has occurred. It's not very loud so if you have your radio playing, you may not hear it.
As for causing other problems, switching gas grades can gum up your cat IF you're switching with an ethanol blend. And usually, a bad O2 sensor will cause the knock sensor code when in reality, your car's not knocking.
~THT
Old 10-01-2004, 05:38 PM
dustrman03
Guest
Posts: n/a
Re: Re: Re: Is Premium gas really needed?
lol and i never took chemistry...lol
