Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-08-2004, 12:24 PM
eclipsefan98 eclipsefan98 is offline
Send a message via AIM to eclipsefan98
Engine question...
I am in the market for an older sentra ('91-'94) and i was wondering would i be better of turboing a regular XE's motor or looking for a SE-R and swatting in a sr20 redtop? i know there are a lot of threads on both but none ask this question. thanks guys
-1996 Eagle Talon
CAI, reprogramed ECU, NGK plugs, and ported head
-1972 Malibu
Mods: 409ci small block replaced the 6 cyl., posi. rear end, low gear ratios, TH350 trans., high comp. pistons, mild cam, no a/c, heater
Old 08-09-2004, 12:18 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: Engine question...
depends on a lot of things. The Swap itself would be cheaper than the turbo for the XE, but you could also find an XE easier and cheaper anyway. Up to you. Either way, you'll end up with one quick sentra and both engines are capable of power that the tranny and tires can barely contain. The absolute easiest(if you can find an SE-R) would be to just turbocharge the stock SR20DE in the SE-R.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 08-09-2004, 09:03 AM
mospeed1 mospeed1 is offline
Send a message via AIM to mospeed1
i would get the xe and drop a sr20det into
i think your insurance will be lower with an xe instead of the se-r
i think a turbo kit for the se-r run around 3000 dollars and you can do the swap for about the same price depending on where you are
02 rodeo ls
old ride 95 200sx full showcar
Old 08-09-2004, 11:07 AM
how ugly would the swap be if i put an sr20de into an XE? i dont want to spend a ton of money. also on fugiot's comment, will the tranny be able to hold up to the upgrade in hp running through it?
-1996 Eagle Talon
-1972 Malibu
Old 08-09-2004, 08:31 PM
fugiot's Avatar
I'm not sure about the strength of the XE's tranny, but the SE-R's can barely hold 200whp. So it might be somewhere around there. Sapping the SR20 into the XE would be the biggest pain in the ass of the 3 options, but it's certianly do-able. And a turbo kit for the SR20DE won't be $3000. You can get on here for $1800. www.jgycustoms.com
Also, I don't think there would be any insurance difference between the SE-R and the XE. Could possibly be lower due to the standard ABS, LSD, and SRS airbags. It's still a FWD Sentra to the Insurance company though.
Don't make me ANGRY
Old 08-12-2004, 03:55 PM
illbeatyourhonda's Avatar
illbeatyourhonda illbeatyourhonda is offline
i disagree with the ser tranny @200 hp. i figure with my setup im close to 325hp and with good solid tranny mounts i havent had any problems. The factory lsd still works and i use my car daily and for solo scca. and who cares about insurance. it would only be a little more exspensive. plus with an early ser like my 91, it has no options which is nice for someone who plans to race it. i.e. no ac no power nothing i love my ser and wouldnt get an xe, there alot of little things youll have to upgrade that you wouldnt think off, like the brakes. and exhaust. things like that.
Old 08-12-2004, 07:48 PM
4doorDET 4doorDET is offline
Send a message via AIM to 4doorDET
if he wants to do a det in a xe let him one hell of a sleeper... i did it in my 4door(look at sig.) and i dont regret it.... sure it was a lot of work but i also gained a massive amount of exprience..
fredo
1994 4 door BBDET auto - manual swap club 16" enkei rims,3'' custom cat-back ,5zigen muffler, GC coilovers, KYB AGX adjustable shocks, drifter bodykit
www.ClubNismO.com
Old 08-13-2004, 03:11 PM
Re: Re: Engine question...
Originally Posted by illbeatyourhonda
i, there alot of little things youll have to upgrade that you wouldnt think off, like the brakes. and exhaust. things like that.
well if he's working on it being fast most likely a brake upgrade and new exhaust is something he would have to do anyways
02 rodeo ls
Old 08-13-2004, 03:36 PM
yes but 90% of people who do power upgrades dont do brakes.....anyway it would be alot less hassle to start off with an ser vrs. an xe because alot of things are already there that you dont have to go out and find like the power steering cooler. and some seats with some for of side bolsters to hold you in around the corners...its just wayt cheaper to start off with the real thing in this case thats all
