Old 08-08-2004, 11:37 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
fixing some susp in the rear
is the back as hard as the front or do the bushing just come out?
Old 08-08-2004, 11:40 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: fixing some susp in the rear
hhhhhhhhuuuuuuuuu?
i really doubt teenage parts will just pop out if thats what your askin
old ass bushings are quite yucky
Old 08-08-2004, 01:45 PM
well the rubber is crack'd all the way throw. i was jsut asking if i well have to grind a metal ring out like on the front
Old 08-08-2004, 05:46 PM
civicwithawankel civicwithawankel is offline
I overhauled my rear suspension-changed all bushings, bolts, etc and I had to use my acetylene torch to cut out 3 bolts that I broke and one of the bushings which was held in place by a broken bolt, then heated all the bushings to press them out, basically you need a torch-propane will work but acetylene is way better... heat everything before you try to remove the bolts and bushings or the bolts will break and they're a real pain to drill out. the old bushings will also be very seized so you need a hydraulic press and lots of wd40 to remove them and insert new ones into the control arms. it would be tough to do it with a hammer (swinging press hehe) but it could probably be done... basically suspension work is a pain in the ass...
