Old 08-08-2004, 10:02 AM
Mr.S Mr.S is offline
I Need Advise!?
I am thinking of buying a 3000GT-96 3.0L V6 with all extra exept leather. Now the only problem is that it have 210.000 miles on it. Im not that good on cars so I was wondering if someone could give me advise if I should buy this car or not. They want $5000 for it! Is there a lot of things that can go wrong after that many miles and is it expencive to fix? And is it easy to add some extra H-Powers to it? Please help me with this... Thanks!
Old 08-08-2004, 11:31 AM
5 Point 7's Avatar
5 Point 7 5 Point 7 is offline
NOOOOOO!!! 5 G's, SAVE YOUR SOUL!!!!
Old 08-08-2004, 01:56 PM
StealthModifier StealthModifier is offline
Re: I Need Advise!?
Save ur money, im sure u can find one with less miles.. im sure that motor doesnt have too many more miles on it.. and if the motor does go it will cost u 8 grand to buy a new one.. or u could find a used one for around a grand.. about the hosepower u would have to spend bout 4-5 grand or so on a SC or staged upgrades.. for hp ur better off getting a VR4
Old 08-10-2004, 11:21 AM
Igovert500's Avatar
blue + red light magnet
Re: I Need Advise!?
As was said...NO!
find one with lower miles...like under 100,000 if possible
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-10-2004, 12:10 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Dude don't get that! We usually don't tell people what to do but that is a horrible deal, I got my 95 SL with leather chromes everything for 5900 and it had less than 100k miles. That car is probably worth 1000, I have seen SLs in good condition with 160k going for 2600.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-10-2004, 12:19 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
If the seller comes down a couple K, I'd consider it if they have meticulously cared for the car and have the receipts to prove it.
Resistance Is Futile (If < 1ohm)
Old 08-10-2004, 12:22 PM
RipDinecola RipDinecola is offline
Banned
I bought a 94 SL fully loaded in brand new condition (really i promise) with 156000 miles on it for 2000 grand. I SWEAR i still cant believe. SO just keep looking JUST TAKE CARE OF THEM AND THEY CAN LAST FOREVER. AND SO WHAT IF YOU HAVE TO PUT A NEW ENGINE IN IT, IT is worth it to drive this awsome machine.
Old 08-10-2004, 10:33 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya, 210,000 miles should say it all!!! don't buy a car with that many miles on it unless you are prepared to spend a lot of money WHEN things go wrong and break. If you are experienced and know how to fix cars, then go ahead, but 5 grand sounds way too much...i'd give him 2 grand max. And you're gonna have to do a lot of rebuilding to the motor b/c you don't wanna give it wide-open-throttle all the time with a motor that old. Don't start modifying the motor until you are mechanically assured that it is running well. Good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-10-2004, 10:49 PM
Thourun's Avatar
Wow 2 grand for that? I wouldn't buy it period. Unless it was like 700, then maybe to part out.
1995 3000GT VR-4
Old 08-11-2004, 12:24 AM
Re: I Need Advise!?
RipDinecola..i know what u meant but u said ur car was 2000 grand.. like it was 2 million! lol
Old 08-11-2004, 01:13 AM
sLADe781 sLADe781 is offline
Re: I Need Advise!?
Agreed. A car with that many miles is not worth it. Keep looking....you'll find one sooner or later.....just be patient.
Old 08-11-2004, 02:00 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: I Need Advise!?
yeah you can find a 2nd gen sl for 6 grand in nice condition with around 100,000
Old 08-11-2004, 07:52 PM
Thourun's Avatar
Re: Re: I Need Advise!?
Thats right, I did :.
1995 3000GT VR-4
