Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-08-2004, 04:31 AM
[email protected] gerard37864@aol.co is offline
Send a message via AIM to gerard37864@aol.co
94 power window problems
I have removed my left window replaced the window regulator and then replaced the motor and i still can't get mypower window to work. Please help. I dont have ant idea what i could of done wrong i installed both parts brand new, I just cant figure out what is wrong with the window
Old 09-19-2005, 10:59 AM
racer8899 racer8899 is offline
There is a relay in the arm rest area that enables the one touch roll down to work that has been causing my window on my 93 vic to quit working. Sometimes it works and sometimes it doesn't. You did not mention if it was the front window or rear but if it is the front, pull your switch panel out and look at that little blue(in my case) relay just under the armrest. My relay has a part number F3AB-14B118-AA. Tap on that and see if it will at least intermittently work and then try to replace that. That is the route I am going.
