Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 02-03-2002, 02:08 PM
furiousd furiousd is offline
Send a message via AIM to furiousd
maxing out
i was semi-racing this guy earlier today, and as soon as the needle hit the end of the speedometer, it was like the transmission just disengaged, and i started slowing down...why?? what can i do to increase my max speeD?
Old 02-03-2002, 07:24 PM
CAptynCrunch CAptynCrunch is offline
Sweet merciful crap! Your racing in a Suburban? You got guts, those things aren't exactly the safest cars on the road. Then again it might actually be the safest, for whoevers inside it. The cars nearby aren't so lucky though.
Oh well, as far as your problem goes it sounds like you've just discovered you cars govorener. Basically it's a little thing that cuts power when you reach a certain speed. Like a honda accord is govorerend at 185 km/h. So when it tries to surpass that speed the accelerator disengages so you can't go any faster.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 02-03-2002, 10:58 PM
Firebird Firebird is offline
If you want to max out your motors rpm and go as fast as posible you can get a reburned computer chip for it. that will let you go as fast as your car can go before drag or redline takes over. you can get one from Summit for around $100-$250 depending on the brand and the type it is.
1989 Nissan 240sx XE(coupe) stock except K&N air filter, and some of the ugliest wheels ever >.<
Old 02-03-2002, 11:26 PM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
A FKING SUBURBAN are you nuts ?
Qualified Automotive Engineer
Old 02-04-2002, 02:41 PM
RiceRocket RiceRocket is offline
Suburban Racer!
Yeah, our friend above is right... youve hit your rides speed limiter. just replace your chip and that should fix it... by the way, who won the race and what the heck were you racing?
CHECK OUT THE STREET RACING FORUM!
http://www.importthugs.com
Check out the site for cool decals, HOT JDM Style License Plate, Race Videos & More!
AF TOFU CREW MEMBER #03 - First Rule of Tofu Crew is You don't talk about the Tofu Crew!
Old 02-04-2002, 04:41 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
on a chevy that is the fuel pump cutoff you hit, roughly around 100.
chevy did it b/c they were cheap and did not put speed rated tires on their trucks/suvs. meaning that over 100, you would have tires that blow up. sooo... they cut the fuel pump at 100...
get a hypertech power programmer, and you can ditch the limiter, and also program your shift pts, etc, and get 20ish hp out of it...
Old 02-04-2002, 09:12 PM
ehh it was some fag in a beamer...he got up to prob 115 in fronta me, then matched the speed of some car in the right lane...thereby preventing my passing him while as the same time displaying his lack of balls...any suggestions for speed-rated tires?
have YOU ever played grand theft auto while driving?
Old 02-04-2002, 09:23 PM
I don't know what your tire/wheel size is but if you can find them in your size BFG's Comp T/A's are nice I think you can get them in S rated and Z rated (correct me if I'm wrong) which would both be rated plenty high enough. plus they get very good grip so you'll be able to launch better too. I'd love to see a big assed Suburban launch hard that would be cool as hell
Old 02-05-2002, 01:51 AM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
on some early and mid 90s ford and chevy trucks, when u hit the limiter if u let of the gas and turn the key froward like youre restarting the engine the speedometer will reset to 0 even though youre still going 100 or whatever your shutoff is, then u can keep accelerating cuz the computer thinks youre going 5 when youre doing 105, 20 when youre doing 120, etc... not sure if itll work on such a new one though. i know this cuz around here its not a big deal for someone to race an suv or truck and that trick is pretty common knowledge.
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
Fuel and temp gauges maxing out?? 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 01-17-2004 11:26 AM
CHeck this max out VQmax95 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 11-16-2003 03:41 AM
maxing out stock turbo flyg20 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 07-13-2003 02:20 PM
Max out! blasian_man COMPLETELY off-topic 8 07-10-2003 02:42 PM
