Old 08-07-2004, 08:45 PM
s10blazin s10blazin is offline
Send a message via Yahoo to s10blazin
85 blazer wont start
I baught this truck in hopes of having minor repair work to do, but after towing it home I find out that the previous owners had already put a new battery in along with wires and a starter. When I try turning it over I only hear clicking from the starter, (i believe) but cant get farther than that. has gas and spark -- i replaced cap rotor and wires and plugs witch all seem to have normal wear.
Old 08-07-2004, 11:25 PM
whatcha/got/racer whatcha/got/racer is offline
Send a message via AIM to whatcha/got/racer
Re: 85 blazer wont start
did u check the work that the other guy did to the starter check for loss connections. there is a really good site to check out coloradok5.com everything that you need can be found in some way there
Old 08-13-2004, 07:11 PM
I repaired the outer wiring and inspected the selinoid all of wich are good. just the selinoid is working.
Old 08-14-2004, 12:27 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
did you take the battery out and give it a full charge?
Check engine and starter grounds too.
Old 08-16-2004, 05:56 PM
boo-hoo
Well it turns out bought a truck that has a siesed motor. the fly wheel wont budge. So now what?!?
Old 08-16-2004, 10:52 PM
BlazerLT's Avatar
AF -Advisor
How do you know it is seized?
If it is for sure, take it back to the seller and demand your money back.
Old 08-17-2004, 01:14 AM
champion69 champion69 is offline
Once time with a 85 4.3 carburated, the motor looks seized after a tune service, I tried turn the engine using the crank pulley screw (15mm), with ratch; no way, then deseperatly come off all spark plugs and tried with engine starts ( ignition coil disconnected) and turns ok; I think that problem should be due a some valve position, another idea is put oil trough saprk plug holes before turn motor. Good luck.
Old 08-17-2004, 11:24 AM
the starter will not turn the fly wheel and niether can i, when i tried to push start the truck the rear wheels lock up when the clutch is engaged so nothing turns over.
Old 08-17-2004, 11:35 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
If you think the motor is seized, try removing the plugs and spraying a Rust Penetrant such as PB Blaster into the spark plug holes. Let sit for an hour, and then add about a tablespoon of oil to each cylinder. Let sit overnight, and try to move the flywheel the next day. I would highly suggest getting a flywheel turning tool, as it will give you much more leverage than just a simple wrench on a torque converter bolts. You also run the risk of breaking a bolt head off. Move the flywheel back and forth until you can move the engine 360 degrees. Turn until the resistance is almost none. Then just to see if the motor moves, try to start it then. If it turns with the starter, replace plugs and try to start it. Just make sure that the engine does have oil in it. If you get no oil pressure within about 10 seconds after startup(assuming it does start), shut it down, and go from there. Hope this helps -Chris
Old 08-17-2004, 12:46 PM
BlazerLT's Avatar
AF -Advisor
^^^^what he said, if not.
Show up at the sellers door very very pissed off.
Old 08-17-2004, 06:14 PM
Re: Re: 85 blazer wont start
alright thanks for the input, i have next week off and i will put it to the test.
Old 08-17-2004, 06:18 PM
many a time i have thought about that, but i would rather turn this truck around and drive it up his @$$
Old 08-17-2004, 06:40 PM
BlazerLT's Avatar
AF -Advisor
why dont you?
Did he say it was seized?
Old 08-17-2004, 09:53 PM
TweakedGM TweakedGM is offline
how long did it sit at his place before you bought it.I like the deisel fuel in the cylinders.
Old 08-18-2004, 07:29 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
The only time that a starter should click is if there isn't enough battery power, and if there is a full charge and the cap and rotor and distributor are intact, and the coil packs, then the motor is more likely siezed.
