Old 08-07-2004, 08:21 PM
Chevy_girl00's Avatar
Chevy_girl00 Chevy_girl00 is offline
Send a message via MSN to Chevy_girl00
20's, 22's and problems???
Okay, i want to put 20's on the front and 22's in the back. I need to know if there's anything else this change will mess with other than my speedometer..... does any one know?? Thanks!
_______________________
2000 Chevy Silverado 1500
Standard Cab, Short Bed
4X4
Perfection is SOO hard to strive for.... especially when you're already there.
Old 08-07-2004, 08:49 PM
02blackstallion 02blackstallion is offline
Send a message via Yahoo to 02blackstallion
Re: 20's, 22's and problems???
You might lose some performance & braking
Black 2002 Silverado Ext Cab, Stepside, Z71, LS, 5.3
Quick Time Performance Electric Exhaust Cutout
Hypertech Power Programmer III
Granatelli MAF Sensor
Kills
5spd Mustang
5spd Civic
Old 08-08-2004, 12:31 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Don't worry about anything. It does take a little extra to stop bigger wheels, but it won't be quite as noticeable unless you get into the 24" range. Most people strongly recommend bigger brakes if you have anything bigger than 22"s.
When you get your wheels and tires on, line up the stockers next to the new wheels and tires and see what the height difference is. If there is none, no need to recalibrate.
*Under Construction - New sig to debut*
Old 08-08-2004, 10:10 AM
lovemytruck lovemytruck is offline
Send a message via AIM to lovemytruck
well i have 20s all the way around on my truck and they have 285/50/20 tired on it which they told me was the recommended tire for my 02 silverado (the closest to my facotry size) but the speedometer is 2 off at 35 so at 35 im really running 37.. but oh well i want some 22s now.. if you put 20s on the front and 22s on the rear could you post a pic for me? thanks
Chris
Old 08-08-2004, 12:26 PM
vnotaro vnotaro is offline
Tire rotation is important for even treadwear on a 4x4. Shouldn't you have the same size all around?
Old 08-08-2004, 03:46 PM
I'm confused by what you are saying. No one said anything about a 4x4. Tires don't have to be the same size all the way around. A lot of people use to put 18's in the front and 20's in the rear, and now some people are putting 20s and 22s on front and rear. Won't mess anything up.
True you won't be able to rotate your wheels and tires, but the tires can be removed and put on the other wheels to help lengthen tire wear.
Old 08-08-2004, 06:03 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
On a 4x4 shouldn't you have the same size all around?
Answer = Yes on a 4X4.
Old 08-08-2004, 08:24 PM
Re: Re: 20's, 22's and problems???
Chevy Girls signature says that her truck is a 4x4. That's why I made the comment that I did. I have had trucks with larger tires in the rear in the past but none were 4wd.
Old 08-08-2004, 10:59 PM
Re: Re: Re: 20's, 22's and problems???
Oh ok, I got. Inibriation is the cause for all confusion.i:
Old 08-09-2004, 09:13 AM
Re: Re: Re: Re: 20's, 22's and problems???
All is forgiven. If I had all the brain cells that I lost 12oz at a time, I would be a f@#$%&g genius!
