I have a 1983 S-10 Blazer with California emissions and the check engine light is constantly on. When you connect the 2 test terminals under the dash the light is still on constantly (no codes). It runs fine. Any ideas?
Re: check engine light/no trouble code
you will need a better way of scanning codes. find someone with a scan tool. if the check engine light is on, there is a code/codes present. i have never seen a check engine light come on without a code. if you use a scan tool and still dont get any codes the only possible problem is the ecm. make sure you are jumping the correct terminals and that you are following the proper procedure when you are jumping them. get a haynes or = manual for that vehicle it will show you how. your best bet is to find a friend or someone with an obd1 scantool.
good luck! |
Re: Re: check engine light/no trouble code
Re: Re: Re: check engine light/no trouble code
So don't let it happen to you find someone who you can trust because the dealers are BS robbers. |
