Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 08-07-2004, 04:03 PM
gotta_learn_1st gotta_learn_1st is offline
fuel controllers
hey, i got another noob question. How do you work a fuel controller, like the arc 2?
Old 08-08-2004, 12:58 AM
TatII TatII is offline
an apexi SAFC is a piggy back setup that intercepts signals from the sensor of your car's on board computers. and what it does is that it tricks the ECU ( electronic control unit ) change the duty cycle of each injector pulse width. however the AFC alone can not know how much % duty cycle to vary by putting larger injectors. you need to put it on a dyno with a wide band O2 sensor hooked up so you can get a good and accurate Air fuel ratio. and its only good for one setting.
example: my car is tuned to only run on 9 psi of boost and nothing more. if i decided to lower my boost, i will run too rich. if i decided to raise the boost, i will run too lean.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 08-08-2004, 03:41 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
there are engine managment systems which you can program yourself, but unless you know what your doing, it isnt a good idea. But it can make it so you want to change your boost, richen yourself out or lean yourself out you can with ease!
(and many MANY other things)
I seen it! I seen it!...it was beautifull
My new RHD project!
Solid Crew (Circa 2002)
Old 08-08-2004, 04:10 PM
Re: fuel controllers
how about a ARC 2?
Old 08-09-2004, 07:13 PM
3GT96 3GT96 is offline
I still confused on the whole fuel controller thing as well??? So say i also buy an ARC 2 right. I go down to get it dynoed, and hook an 02 sensor up 2 it. then how do i find out the duty % cyle from that??? and then all i do if plug that number into my fuel controller, and im ready to roll???? im totally lost thanks
Old 08-10-2004, 08:27 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
You figure out the duty cycle by finding out how much larger the fuel injectors you put in are over stock. Hypothetically, if you had 100cc injectors stock and put 200cc injectors in, the duty cycle would be 100%. Obviously the computer won't compensate that high, but you get the picture. The wideband I beleive is used to tune at certian RPM bands to get a desired A/F at specific RPM ranges. Somebody correct if that is wrong. BTW, tat, what size T04 are you using?
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
