Old 08-07-2004, 02:56 PM
dosif dosif is offline
rotors?
I took off my calipers and I cant seem to get my rotors off. is the nut in the center holding the rotor in or what?
Old 08-07-2004, 03:38 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: rotors?
You didn't say what year GP you have. On the newer cars you need to remove the caliper mounting brackets before the rotors will come off, front wheel drives. If you have rear wheel discs the same applies. If you have an older model GP, rear wheel drive, you will need to remove the nut that holds the wheel on and pull the rotor and hub assembly off the spindle to change the entire assembly.
Old 08-07-2004, 03:40 PM
Re: Re: rotors?
i have a 98 gt, im trying to take off the front rotors.
Old 08-07-2004, 03:43 PM
Re: rotors?
i already took off the caliper mounting brackets, but the rotors wont come off. do you know if they are supposed to just pull off or are they secured by a bolt?
Old 08-07-2004, 11:00 PM
Z987784 Z987784 is offline
Re: Re: rotors?
Sometimes the rotors become seized in place over time. A good tap with a rubber mallet might break them lose.
Old 08-08-2004, 11:07 AM
Pontiac Guy
Re: rotors?
The bolt only holds the axle shafts. A little gentle persuasion with a hammer should loosen the rotors. You may also want to try spraying the area around the rotor and the axle with some WD 40 or PB Blaster and wait a little while before tapping with a hammer. This should loosen the rust that is holding the rotor in place.
