Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-07-2004, 01:56 PM
A1AFLA A1AFLA is offline
95 Dakota A/C & cooling problem
My 95 Dakota has a small leak from what appears to be the Raditor. Upon further investigating, the leak may also be coming from the A/C condenser. It is leaking Antifreeze. I am fairly certain that I will have to replace either the Radiator or the Condenser, Maybe both? Does anyone know if a bad condenser will cause problems to other parts conected to the Condenser? I am fairly certain that the clutch on the A/C went bad before this all started. Could this have caused the problems I am having now? It think I could manage the repairs by myself, though it looks like it might be a lengthy one. Any ideas on this would be much appreciative.
Old 09-13-2007, 12:26 PM
JayinCordova JayinCordova is offline
Re: 95 Dakota A/C & cooling problem
I am interested to know what you find out. My 95 v6 is leaking also and I can't locate the leak. The overflow bottle runs low after 3 or 4 days of driving. I have determined that it's not leaking into the crank.
Old 10-01-2007, 06:50 PM
mikec041 mikec041 is offline
A/C condensers don't contain antifreeze.
Would look for radiator/hose/water pump leak that's dripping/spraying on the condenser.
Old 12-27-2007, 01:57 PM
ryobiguy ryobiguy is offline
try the bypass hose from the block to the water pump. my 99 leaked for about 5 years before it was found leaking. Oh yeah its tough to get to. good luck.
