Old 08-07-2004, 01:17 PM
nouseforaname nouseforaname is offline
'98 Cavalier belt tensioner bolt HELP!
Hello,
I'm in the process of changing my drive belt on my '98 Cavalier and I can't seem to locate the belt tensioner bolt. So, if anyone could help me with a description or a link to the belt tensioer location that would be most appreciated. Thanks.
Old 08-17-2004, 01:04 PM
bdodge bdodge is offline
bolt location
the bolt is located in the center of the belt tensioner. The book says to turn clockwise, but I found if you are looking at the engine from the passenger side you need to turn the bolt counter clockwise. The tensioner is spring loaded so you need elbow grease. turn as far as possible then remove the drive belt.
Old 08-18-2004, 12:39 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: '98 Cavalier belt tensioner bolt HELP!
um.... no. Not counter clock wise. The tensioner is under the upper engine mount, the pully right under that. Great place for one Eh? When you are on the passenger side hovering over the Coolant resovoir... the engine mount should be right in front of that with the pully right below that. Get a wrench on it and pull it towards the front of the car. Clockwise....some people need to think first.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 08-18-2004, 10:39 AM
I have a 98 2.4L Cavi and I just ran into this 3 hours before I posted the message, Go ahead and turn it clockwise, see how far that gets you
Old 09-01-2008, 01:00 PM
Lytlboiblu Lytlboiblu is offline
The tensioner is the pully closest to the alternator. should be down and to the left
you need either a breaker bar (socket rench that doesnt rachet) or an N wrench depending on weather there is a bolt or square hole.
turn this CLOCKWISE as far as you can and HOLD IT until you (or someone else!) takes the belt off of the alternator. then GENTLY release the tensioner. take note of the layout of your belt. there should be a diagram somewhere under the hood that shows you.
Old 09-01-2008, 08:14 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
vote #3 for CLOCKWISE
i have no way of knowing which engine your dealing with but this thread MIGHT help
http://www.automotiveforums.com/vbul...d.php?t=309192
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 07-18-2010, 10:29 PM
fostmt fostmt is offline
What engine do you have because i have a 2.4l and it turns counter clockwise. Looking at that illustration of the 2.2L i can tell that it depends what engine you got because on the 2.4l there is no water pump and the tensioner pulley is located right under the alternator pulley and the only way to turn is counter clockwise(towards the back of the car). So everyone is correct it just depnds on which engine the person had.
Old 08-19-2010, 02:56 PM
rich4 rich4 is offline
I just replaced the serpentine on my 96 and if you trun the bolt to the right (front of car) you remove tension on the belt and if you turn it to the left you remove the pully.
Hope this helps you
rich4
Old 10-21-2010, 07:57 AM
meddy03 meddy03 is offline
Hi;
I have the 2.4 as well and the bearing is gone in the tensioner pully. I do recall changing the belt years ago and did use a wrench on the bolt to move the pully back, turning counterclockwise. But to get the bolt to turn to change the pully, has anyone ever done this before. Am hopeing once it bottoms out on the rotation it will turn but am not sure. Have a hanes book but does not say one thing about the belt system.
Thanks
Old 10-21-2010, 08:10 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
I am not familiar with a 2.4....but I just change the Idler Pulley and put a new belt on eliminating the A/C compressor... Pull down or the the right to loosen the belt. The bolt is a Std thread... turn to the LEFT to loosen it....
Cheers my Friends....
Old 10-21-2010, 08:16 PM
Helmuth48's Avatar
On my 96 2.2....the BLUE Circle - idler is also the tensioner !!!!
Old 10-22-2010, 07:24 AM
Hi
On the 2.4 the tensioner pully is one unit so to speak, and it is about 2-3 inches above where the water pump is.Just not sure on how to get the pully off, as FOSTNT noted to change the belt you turn the bolt counterclockwise to the back of the car. Would be good to know if it is a standard or reverse thread bolt before I start wailing away on it.
Tks
Old 12-29-2010, 01:58 PM
raychoate76 raychoate76 is offline
Send a message via Yahoo to raychoate76
how difficult are these to change out I seem to be missing one entirely my car was equipped but somehow along the way it fell off in the last few days
Old 02-23-2013, 10:53 AM
dhil4895 dhil4895 is offline
Thumbs up Re: '98 Cavalier belt tensioner bolt HELP!
I just finished replacing my alternator in a 97 sunfire 2.4 (same engine as cavalier) and after reading all your posts and trying "clockwise" rotation I found that bdodge is 100 percent correct in stating that is goes "counter clockwise" to relieve tension (at least for a 2.4). I actually found some diagrams that proved his statement is true. (see below)
http://www.google.com/search?q=98+2....w=1280&bih=699
bdodge, thank you for your post which pointed me in the right direction
