Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 08-07-2004, 12:49 PM
DiGiTaLEcLiPsE's Avatar
DiGiTaLEcLiPsE DiGiTaLEcLiPsE is offline
Send a message via ICQ to DiGiTaLEcLiPsE
Need Help Adjusting MT2
Need help adjusting my mt2.
I have a few problems I don't know how to deal with I'll try to list them now
1) When I put it full throttle the car starts turning by itself?
2) How do I adjust it so the car stays still when on neutral? Can't seem to get it to stay still I have been trying to adjust it for awhile.
3) How do I get it so when I hold brake there's a lot of braking force but doesn't stall?
Example. I adjust it so the carb is open about 1mm when on neutral but when I push the brakes it closes?
That's all I have for now.
Old 08-07-2004, 04:40 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Need Help Adjusting MT2
If you bought a nitro car, You should know how to fix it...
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-07-2004, 05:15 PM
Uhhh.. why are you so mean to me?!
Old 08-07-2004, 05:32 PM
pre98zetec's Avatar
Not mean, If you can't fix it, why buy it?
I was gonna buy a nitro, But I have no idea how to fix them.
-Josh-
Old 08-07-2004, 08:18 PM
So, if you don't know how to fix them please shut up. I want to learn how to fix it. I have to learn how to fix it to know how to fix it. If you're not going to help me just shut up.
Old 08-07-2004, 08:34 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
This is why I suggest that you get an electric...but noooo, lets not listen to people that know what theyre doing now.
-Mike
Old 08-07-2004, 08:38 PM
pre98zetec's Avatar
If your car break's down, do you know how to fix it?
What about if the lawnmower doesn't start? Can you fix the problem.
If both of those question's you awnsered with a no, Then you should have got a electric. Because the motor's are just about the same.
-Josh-
Old 08-07-2004, 09:10 PM
Hey, I respect that you suggested to get an electric for my first car but it was a good offer.. $300 CND for a MT2 with spare parts, 12 AA recharables 2100mAh, Rotostarter 7.2V included 1500 mAh, new air filter, 1 gallon of gas and glow plug igniter + charger. For $300. Tell me if it's worth it.
Old 08-07-2004, 09:20 PM
pre98zetec's Avatar
Just cause it was a good deal, Is it worth the headache its gonna give you trying to fix it?
-Josh-
Old 08-07-2004, 10:16 PM
Yes.. And btw my car didn't break down, just can't adjust the carb properly.
Old 08-08-2004, 02:48 AM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
Sounds like a glitch. Check the wires going to the stearing servo, see if they are frayed or if the connection is loose at the receiver. Check to see if the antenna wire is touching anything metal, if so just pull the slack (if you can) through the antenna tube. Check the screws and make sure they are all tight. If it still does this, then take it to your local R/C car shop and have them look at it. If they are clueless, go to www.rccaraction.com and check out their forums for better answers.
Well, remove the brake linkage and make sure the throttle servo horn centers when the transmitter is centered. Reattach the linkage and before tightening it up, adjust it so the throttle is closed...it should close compleatly...the idle needle inside is what should be at 1mm or so. If it still creeps, then loosen the adjustment nut and moce the rod so it puts a bit more pressure on the brake disk while in neutral. Also, what might help, git rid of the plastic brake disk and get HPI's fiber disk...works alot better.
See above...carb closed...idle needle at 1mm. It's the little screw to the right of the air filter. Tighten or loosen to adjust the idle up and down. Sounds like the idle might me a bit too low. Also from R/C Car Action's web site, you can order so good books on Nitro and electric car basics, trouble shooting and tuning tips.
Now how hard was that? You may not have intended to be rude, but that's how it came out. As for the electric thing, if a new person to the hobby can't fix one, they probably can't fix the other. If people didn't buy things because they couldn't fix them, no one would buy half the things they do. Hell, why buy a real car? I can fix most things on a car, but tranny and electrical work? Not a chance. Does that mean I should not have one...no. Hell, 70% of the people who buy real cars are clueless on how to fix them. But at least with R/C cars, one can usually get help learning how to tune and fix these things by doing a bit of research, buying books, asking questions on helpful forums...
For first timers that want Nitro cars, I usually suggest getting a kit over a ready to run. Not as cheap for what you get, but if something breaks, you built it and are a bit more confidant at fixing it. Also, somethimes the instructions in a kit are a bit more detailed.
/rant
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 08-08-2004, 02:49 AM
Asmenoth's Avatar
AF Premium User
And yes, that is an awsome deal. Hell, I bought the MT Racer a few years back and it cost me $300 US and I had to assemble it and buy my own electronics and an engine.
Old 08-08-2004, 09:50 AM
THANK YOU ASMENOTH!
Good thing this is a helpful forum with noone critisizing you about which r/c cars you buy and good thing noone tells you that you were better off buying an electric because you can't fix nitro...
Old 08-08-2004, 12:27 PM
STINKINLINCOLN's Avatar
STINKINLINCOLN STINKINLINCOLN is offline
Send a message via AIM to STINKINLINCOLN Send a message via MSN to STINKINLINCOLN Send a message via Yahoo to STINKINLINCOLN
BUY what you want you need to learn sooner are latter How to fix them yourself so anyone telling you different is wrong
however I have a electric car for my first car
and I have ran into a small prob with the stearing.
I could have bought a gas power car for a extra 100 dollars but I thought that 450.00cdn was to much for a r/c car
so my advice to you do what ever the hell you want
93" LINCOLN CONTINENTAL
69" BUICK RIVIERA
1988 MAZDA B2200NEEDS HELP
http://www.geocities.com/jjbannon81/69RIVIERA.html
1999 OLD ALERO
Old 08-08-2004, 02:01 PM
Asmenoth's Avatar
AF Premium User
THANK YOU ASMENOTH!
You're welcome. I try to answer what I can, as I feel bad for this part of the forums...kinda neglected compared to the modeling forums.
