Old 08-07-2004, 11:30 AM
mpitts mpitts is offline
Question fuel filter replacement
Hello,
I'm new to this forum. I have a question. On my 93 S-10 4.3 liter w engine, do I have to bleed off pressure in fuel line before I replace my fuel filter? If so where is the bleed point? Also is there a how to page or any helpful tips type place in this forum?
Matt C.
Old 08-07-2004, 11:36 AM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
Re: fuel filter replacement
http://mywebpages.comcast.net/gsussm...eplacement.htm
http://www.p-car.com/diy/fuelfilter/
i couldnt find the site i used when i did my fuel filter but heres a few
Old 08-07-2004, 08:03 PM
busa_4 busa_4 is offline
all you have to do is remove the the fuel pump relay and crank the engine for about 5 seconds. it might start and die out or it might only crank. this will relieve the fuel pressure. make sure you remove the gas cap as well to make sure there is no pressure in the tank. good luck!
Old 08-08-2004, 06:37 AM
Re: Re: fuel filter replacement
Thanks for the info on the pressure relief.
I'll look for the relay, I'm assuming it's in the fuse block.
Old 08-08-2004, 10:51 PM
www451oa www451oa is offline
I've changed my fuel filter a few times and havn't bled off the pressure. Just be careful when losening the lines not to put any prssure on them. Once you break the seal, fuel will come out, not much, maybe 1/4 cup worth. Change the filter, then when you go to start it, let the pump pressurize the system, and it may take a second try to start it, allowing the air to be forced out of the lines through the engine. And your all set. Very easy.
Old 08-13-2004, 03:10 AM
dwinthrup dwinthrup is offline
make sure you look away gas burns the eyes if you look at the line by the engine to the fule rails there is a thing looks like a steal valve stem push that in carefully that would do it bu make sure you gas cap is off
