Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 08-07-2004, 10:19 AM
FordBoy33's Avatar
FordBoy33 FordBoy33 is offline
2003 LS - are these orig wheels? CD changer, fog lights
Thinking about buying a used 2003 LS. It has some chrome wheels which I would not have expected on it. Can anyone tell me if these are the "chromatic" (can't remember exactly what it was called) wheels that were available as an option on the car in 2003? The seller is telling me wheels and tires are orig (Contiental tires?).
How do I tell if the car has optional features (traction control, ABS)?
Also, this thing is missing the trunk CD changer. Sounds like an easy addition from what I see on crutchfield's site.... That so?
Finally, it's missing the fog lights (bumper replaced after front-end wreck). Are those easy to get?
Thanks.
FordBoy33
2001 C1500 Suburban LT
1993 Mustang GT *** for sale ***
2003 Sable LS (Duratec)
Old 08-21-2004, 12:01 AM
Froze_Tread Froze_Tread is offline
Send a message via MSN to Froze_Tread
Re: 2003 LS - are these orig wheels? CD changer, fog lights
Never seen those rims yet and they dont look like ford.
The dealer or someone through those tires on thier they should be coming with goodyears if i remember right. mine did 2002.
If Fords didnt break all the Time i would be out of a job and a few million other Ford mechanics. Just like the Firestone incendent.
Old 09-03-2004, 11:17 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
those ARE factory rims on many Sable LS's They're definitely the blinginest rims ford ever put on a Taurus/Sable. They also did come with Continental tires. All Gen 4's came with Continentals.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-30-2004, 10:29 PM
mmatting's Avatar
mmatting mmatting is offline
re: the part about the CD changer
I just did a CD changer install, ironically from Crutchfield - not a factory unit but built to spec. Crutchfield gives pretty good instructions and tech support is included if needed. There are usually some of them on E-bay as well. The wiring harness plugs right in and takes about 3 minutes once you get the pushpins out of the trunk liner. I mounted it on the ceiling of the trunk and it works well. Controls are easy to use on the control panel. It does not give the name of the artist and title of the track like some of the new ones do, but it does keep track of disc number and track number, and it sounds just fine. Whole job took about three hours from unwrapping the box at the start to reinserting the pushpins in the trunk liner at the finish. You will need a drill and drill bits and phillips screwdriver, but no soldering iron or wire connectors; there was one ground wire on the CD changer part of the harness but other than that the wiring was strictly plug and go. Good luck - let me know how it goes!
