bad idle,. miss ? vacuum guage needle moves
1987 22R-E
one new injector, new PCV new fuel filter new fuel pump disconnected EGR valve new spark wires plugs old engine misses at idle, especialyl when hot, will stall sometimes especialyl if in gear at dead stop, sill miss miss stumble die just cant keep itself runnign too well a tlow RPM, but at the instant you hit the gas to go its all there full power great like it should be vacuum guage shows 20 inches of mercury at idle and needle consistently fluctuates a few inches not alot of inches just a few within good range but its constant and even miss with the idle speed, other than new plugs what else can i do ? cat converter plugged ? thanks for anything
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
Re: bad idle,. miss ? vacuum guage needle moves
Assuming that there are no other symtoms you are overlooking, I would hazzard to guess you have a bad vlave(s). Pull your plugs and "read" them, you may find a clue here.
cat converter plugged ? No because it would run worse as RPM and load picked up. Nate |
