Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-06-2004, 11:36 PM
oldsgal442 oldsgal442 is offline
Send a message via AIM to oldsgal442 Send a message via MSN to oldsgal442 Send a message via Yahoo to oldsgal442
Unhappy bird won't run
i have a 1985 thunderbird. i have change the following items on the car and still won't run. battery,plugs wire,plugs,oil filter,oil, checked starter, chand ingion module, checked fuses,fuel pump, reset the fuelpump,put fresh gas, and checked the fuel injection. i don't have any ideas on what else to check or change and the is still a collector if i can get it to start and stay running. thanks please help
Old 08-06-2004, 11:38 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: bird won't run
Does it make any sounds?
Will it spin over?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 08-06-2004, 11:44 PM
Re: Re: bird won't run
Will it spin over?
yes it spin but won't stay running will try and start but just wears the battery down to nothing .but it is staring hard it just kick in.
Old 08-07-2004, 04:18 AM
emailer33 emailer33 is offline
Send a message via AIM to emailer33
Re: bird won't run
MIL light on? you pull any codes from like a KOEO test?
Old 08-07-2004, 09:46 AM
[quote=emailer33]MIL light on? you pull any codes from like a KOEO test?[/QU
what is the mil light and no codes are coming up.
Old 08-07-2004, 09:30 PM
Re: bird won't run
mil = basically the "Check Engine" light.
Old 08-08-2004, 12:44 AM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: bird won't run
An engine needs 3 things to run. Air, fuel, and spark for a gasser. Make sure you have proper fuel pressure/delivery, spark, spark timing, firing order, and air supply. Does it backfire through the exhaust or intake when it tries to start? Does it cough a couple times and not start or will it fire but not catch long enough to run?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-12-2004, 06:54 PM
Wattsyurz's Avatar
Wattsyurz Wattsyurz is offline
Send a message via Yahoo to Wattsyurz
Re: bird won't run
Nobody has asked what engine your car has. If it's the turbo, I had a problem like this. It ran me ragged for a while until I pressure tested the fuel rail. The in-tank electric pump was bad (ruptured small rubber line). Mine would idle if the tank was full. If this sounds like a possibility, don't repair the pump. Install a new one and make sure the tank goes back in once!
Wattsyurz
Old 08-14-2004, 05:12 PM
no the check engine light is not on and there are no code coming up either.
Old 08-14-2004, 05:17 PM
Wattsyurz
the car as a stock 302 fuel injection no turbo
Old 08-15-2004, 10:23 AM
Re: bird won't run
Can't remember so I ask, is an '85 port or throttle body injection? If it's port, have you tried starting the car with the accelerator at part throttle? If not, try it and if it runs, you should look into a new TPS.
