Old 08-07-2004, 12:18 AM
songsandstars's Avatar
songsandstars songsandstars is offline
Send a message via AIM to songsandstars
i need an indiglo transistor box....i think
i recently installed indiglos in my '95 LX. everything hooked up great and functional...until 2 minutes later. they turned themselves off, only to turn themselves on again a minute later and continued to do this for a while. i went back and checked all of my wiring, and it's all right. the ground is secure and all the other wires line up fine. my only idea as to what the problem could be is to replace the transformer box that runs between the indiglos and the dimmer/color switch. so does anybody have some advice as to what to do or know where i can get one of these boxes? any help at all would be greatly appreciated...thanks....
Old 08-13-2004, 01:10 AM
TheOutsider TheOutsider is offline
Send a message via AIM to TheOutsider
Re: i need an indiglo transistor box....i think
sounds to me like you have a grounding problem....what did you ground it to?
Old 08-13-2004, 08:27 AM
i grounded it to the ground wire from my origional dimmer switch. everything works now, but when i press on my brakes, everything in my car dims for a second and then comes back to full strength. alternator? battery? what do you think it is?
Old 08-13-2004, 03:57 PM
alternator maybe......hrmmm...i dunno...........i just put some bomz indiglo gauges in my car, and after i worked out a few small bugs, everything has worked fine
