Old 08-06-2004, 11:30 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
Ordering dsmlink some ?
All right i think i am finally gonna order the damn thing, on the order it has rev limiter and launch what am i suppose to do with those two things!?
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 08-07-2004, 12:10 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Ordering dsmlink some ?
put whatever rpm rev limiter you want... and for the launch i believe thats for s studder box, put down whatever rpm you like to launch at best!
Old 08-07-2004, 12:44 AM
Fred95GSX's Avatar
Fred95GSX Fred95GSX is offline
I thought the website was pretty informative. What are you asking exactly?
Why are you spending the money on a DSMLink when your website mod list is pretty short. When you go to upgrade your injectors you are going to have to get a new chip. I'd at least look at getting new injectors at the same time so you can save a few dollars. Good choice on picking the DSMLink over the AFC. Knowing all the choices available for 2Gs right now, I'd never get an AFC and would pick the DSMLink or ECU+. I'd get the ECU+ if money was tight and you didn't have an EPROM ECU available.
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 12:51 AM
Nstyle29's Avatar
well i want to see what my car looks like right now instead of slapping a bunch of other mods on then trying to tweak it all...just heard it was a good idea
Or should i put that money towards some injectors and turbo? For the EvoIII 16G , 550cc injectors should be efficient right?
Old 08-07-2004, 01:01 AM
Fred95GSX's Avatar
It is a good idea to learn to tune before throwing on "big horsepower" parts. I am just trying to point out that you can save a few bucks by installing injectors and getting the DSMLink chipped for them at the same time. The larger injectors won't hurt anything right now since the DSMLink automatically compensates for them.
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 01:04 AM
Nstyle29's Avatar
guess i will have to wait a lil longer, i see your reasoning, but to get the injectors and dsmlink at the same time argh, damn college tuition screws it all up
Old 08-07-2004, 01:10 AM
Fred95GSX's Avatar
If you think it will be a few months before you next mod getting the DSMLink now and getting used to tuning with it wouldn't be a waste at all. I'd just hate to see someone spend money on a product and then have to upgrade it in a few weeks.
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 01:11 AM
Nstyle29's Avatar
i gotcha, thanks...probably will just wait and find some 550cc on tuner or ebay or something then place the order for the dsmlink
Old 08-07-2004, 04:14 AM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
i'm not telling u what to do, but getting the DSMlink will be deff going to be a nice upgrade, at any point of your cars upgrading. also i don't think your chip will be set for a sertain size injectors. thats the hole point ,you can run any size of them with the DSMlink. and not to mention all the other extras coming with it. for sure u will get a power increase imideatly. again i might be wrong, but if i had an EPROM ECU in my 95 GST(with my luck i didn't) i would deffenetly buy it right away. i think that DSMlink is a must with these vehicles... my 0.02$... i mean you simply can only gain once u have it, no mather what...
[IMG][/IMG]
Old 08-07-2004, 10:18 AM
rodknock rodknock is offline
Send a message via AIM to rodknock
i recently have been thinking the same thing. Theres a guy in town who's got a 98 gst with a couple of bolt ons and an aem ems and he swears by it. Now ive seen his dyno print outs and there incredible 300+ to the wheels. I have decided an ems would be my next mod. The injectors id probably wait on till i pick up my t/kit
Old 08-07-2004, 01:11 PM
Fred95GSX's Avatar
The AEM EMS is the best out there hands down. Most people wouldn't be able to handle having complete control of their engine like that. It takes a very good understanding of how everything interacts together to pull off tuning with an AEM EMS. That's what great about DSMLink, it gives you a powerful tool to tune with, but still leaves you room for safety. Most of the low throttle maps remain the same since one of the main features is having your injector size built into the ECU's own coding.
ECU+ has injector size selection in it's programing.
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 01:20 PM
Fred95GSX's Avatar
Originally Posted by The DSMLink FAQ
- What happens when the battery is disconnected from the car?
When you order DSMLink, we'll ask which injectors you have. We then burn a chip with default settings for those injectors. So yes, if you loose power to the ECU, DSMLink will still function properly. It won't "forget" anything necessary to run your engine. The things lost will include the adjustments you made to the stock timing and WOT fuel tables. The stock values are still there. You'll simply revert back to those values when the ECU powers back up.
http://www.dsmlink.com/faq.html
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 01:40 PM
Nstyle29's Avatar
so then you would have to send it back to get it reprogrammed once you got larger injectors?
Old 08-07-2004, 01:58 PM
Fred95GSX's Avatar
Either send the chip back or just buy another chip. I'm sure it's a lot like the upgrade for V1 owners. Pay $50 and get a new chip sent to you.
Fred
95 Eclipse
04 Quest
Old 08-07-2004, 02:10 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
I bet they will probably do a core swap, since they could most likely resell the chip if you sent it back to them.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
