Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 08-06-2004, 10:17 PM
blazzingbrandon blazzingbrandon is offline
Send a message via AIM to blazzingbrandon
Exclamation Radio Harness
I was going to change the radio in my 97' runner. I tried to get a wire harness but It couldn't fit, so I just cut the factory harness. I tried to connect it to the aftermarket radio but the wires aren't the same, can anyone tell me the wire colors for the runner and there functions. and another thing, I have 2 cables in, I know one is for the Antenna, but what is the other one for. Finally, since I couldn't put un the aftermarket radio, I just put in the factory radio back in, and now it won't work, just a red light blinks. I know the code, but I can't acces it, the manual said to press 1,tune ^, at the same time, but it still won't work.
Old 08-07-2004, 10:00 PM
Tomsriv Tomsriv is offline
I bet a radio shop would know which wire goes where. I would return the aftermarket stereo, then find the same one at a shop with free installation. Then let them deal with it.
Otherwise you will need to splice the wires back together, or get a wiring diagram to figure it out.
Old 08-21-2004, 04:27 PM
onetopproducer onetopproducer is offline
Harness problem solved
Have no fear radio harness is here. Just a few bucks and your back in business. The 97 4Runner Lmtd radio harness should be identical. Give me a 60% price of the dealers and you got yourself the harness. Email me.
Old 08-21-2004, 11:39 PM
Re: Radio Harness
Its ok, i figured it out already and i got the problem solved, by the way, here is my 4runner if anybody wants to see: http://www.cardomain.com/memberpage/252927
Old 07-26-2005, 09:04 PM
AquaMaya AquaMaya is offline
Re: Re: Radio Harness
I am replacing the unit in my 99 4RUNNER and am having the same problem with the wiring and two antenna wires. Where did you hook up the smaller antenna wire? Do you know what it's for?
Thanks in advance
Old 12-06-2005, 08:23 PM
bassmastry101 bassmastry101 is offline
Send a message via AIM to bassmastry101 Send a message via Yahoo to bassmastry101
Re: Radio Harness
www.crutchfield.com
just wire your old harness back up and go to the site and buy a cheap aftermarket harness.
