Old 08-06-2004, 09:10 PM
02HondaCivicEX 02HondaCivicEX is offline
Exclamation I want to make my car a high performance car... Please reply! I'm new to this forum!!
I have a 2002 honda Civic EX with a factory performance kit installed which pretty much means I have nicer alloy wheels, front, side, and rear ground effects ( I think that's what it's called anyway) and fancy dash trim. I recently had the windows tinted, so by the looks of my car everyone thinks it has just as many updates under the hood but really it is completely normal, only has what honda gave standard. I think it has a 1.7 L VTEC 4cyl. 127hp engine. I recently got an exhaust from a friend that I am going to have welded on ( the only thing I know about it is that it is very wide and says R1 racing sport on the side). Basically what I want to do is install some "under the hood upgrades" and stuff that will make my car somewhat decent. I don't want to create a full-blown street racer or anything. I just what the basics or the things that will make it average or respectable. I don't really want to spend a fortune either, so I am looking for some somehat inexpensive tweaks. Could anyone please tell me what they recommend I should do? I'd appreciate it!!!
Old 08-06-2004, 09:26 PM
Question I want to make my car a high performance car
Old 08-06-2004, 09:46 PM
MunG35's Avatar
MunG35 MunG35 is offline
Send a message via AIM to MunG35 Send a message via Yahoo to MunG35
Re: I want to make my car a high performance car
search damn it, most asked question on this forum
Are stock tips worth anything? See how the experts do: http://www.stocktiptrader.com
Old 08-06-2004, 09:49 PM
ITLNstallion818 ITLNstallion818 is offline
Send a message via AIM to ITLNstallion818 Send a message via Yahoo to ITLNstallion818
chill out, hes a noob-- what do u expect?
Old 08-06-2004, 09:55 PM
well I have searched but I don't know what the best additions would be
Old 08-06-2004, 09:59 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Him to search.
Basics: Cold air intake, header, exhaust (which you already have). But your car will still be slow (but "peppy") unless you go turbo, upgrade the cam, supercharger, or nitrous. With the setup you have now you'll have low 130's hp with basic bolt-ons.
I think someone should do a newbie question/answer sticky of the most asked questions.
Old 08-06-2004, 10:05 PM
what should I expect to pay for those suggestions?
Old 08-06-2004, 10:08 PM
CivicSpoon's Avatar
There is no Spoon
Depends on what you go with, if you go for the generic e-bay way it will be considerably less but they won't give you as much power. Search around e-bay and google and check out different brands; find one you like and then search for the best price.
Old 08-06-2004, 10:10 PM
ok, thanks!!
Old 08-07-2004, 01:53 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
i got my cold air intake of ebay for 45 dollars, and a short shifter for 20, dont feel much faster tho.
turbo setup - 2K
nitrous 700-1000
camshaft 200
cam gear 80
lightened flywheel 300
lightened crank 100
you can also gut the nice new interior, remove all the sound deadener, backseats, front seats, carpeting, everything u dont need
with big horse power come big responsibilty to drive safely, or to just slam the brakes when you see the cops:
brembo big brake rotors
stainless steel brake lines
semi metallic brake pads
dont forget a spoiler to keep those back tires on the ground hehe
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 08-07-2004, 01:57 AM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
engine work is like a bottomless pit... little cash won't get you far unfortunatly.
you could get the basics: intake, header, exhaust..maybe some plugs and wires.
there are internals for n/a setup: top end(camshaft, cam gear, etc) or bottom end(pistons, rods, etc)
you could peice together your own turbo(my current project ) which if you do safely will net you some very significant numbers for fairly cheap(hmt setups usually run about 800-1500 depending on hookups and ghettoness hahah)
goodluck
-Luke
Old 08-07-2004, 03:52 AM
NerveAgent's Avatar
NerveAgent NerveAgent is offline
intake, header, exhaust thats all you need.
Old 08-07-2004, 03:56 AM
NerveAgent's Avatar
btw why the hell did you make two threads? (on the same topic)
Old 08-07-2004, 04:11 AM
GTR...GTR...GTR's Avatar
GTR...GTR...GTR GTR...GTR...GTR is offline
if you want real power get a b18 b or c motor then send it to http://www.importbuilders.com for the works
Old 08-07-2004, 11:34 AM
Beastiek2's Avatar
Beastiek2 Beastiek2 is offline
Banned
Send a message via AIM to Beastiek2 Send a message via MSN to Beastiek2
First off yea chill out noobs. Second You have a 7th gen civic 01-04, not the best of civics. The swappable motor for our cars in the Acura Type S engine k20. Not the b18 which will have to have custom mounts, which will give you sh*t horses compared to the k series. But this will cost you a heafty penny. As for cheaper upgrades that will make your car sound better are the intake, headers, exhaust, high flow cat, cam gear, regring cam. These wont make your car to much faster but it will help out and wont break your wallet. As for more performance you can throw a turbo on there. There arent many comapny producing 7th gen turbos yet, but they will get you around the 180-190whp with booting at 8psi. This will run you 3k for the set up. My suggestion is go for suspension first. Throw some spring and shocks on the car, sway bars, tie bars this will make you car much more enjoyable to drive. The best web site to look around and read about the 7th gen civs would be 7thgencivic.com.
