Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-06-2004, 08:17 PM
superman0604 superman0604 is offline
A/C Vent
The center vent on the dash is cracked. How do you remover the plastic peice holding the vent in. Also does anyone know a place to get a replacement?
Old 08-07-2004, 06:23 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
Re: A/C Vent
94 - 00 Integra Center Air Conditioning Control Assembly...
Im gonna try to explain it for you I take no responsibility for your actions. Use Instructions at your own risk, Thanks.
1. Go Disconnect your battery, also make sure your (SRS) is off. Or Your aka: Airbags.
2. remove your rear defrost switch out of the dash with a flat head screwdriver. Then disconnect the electric connection.
3. Now remove the Emergency blinker switch the same way. Dont forget to remove the electric connector.
4. After removal of the two switches if you look inside there will be some screws... well unscrew them and semi pull the whole panel out. Disconnect all the wiring harness's before fully removing the panel. - To Re-install the process is reverse.
Need to find a replacement...
Look in a junk yard.
Buy from dealer.
Buy off ebay.
If you cant find it in those places search the net... im sure u will find something
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
