Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 08-06-2004, 04:06 PM
ugsrich ugsrich is offline
Horn Problem, 1995 Aurora
My horn works only when the steering wheel is within about +-2.5 degrees of top-dead-center. So, in a turn the horn does not function at all. In fact, if I start honking while going straigh (top-dead-center) and start to turn the horn stops.
I have the factory service manuals for my vehicle. The illustrations are not completely clear and I would prefer to better understand the switch and connection between the wheel and column.
Has anyone pulled your steering wheel? Can you give me a good description of the horn switch/connection?
In this specific case I would appreciate responses from individuals that have personal experience with this problem and have even personally rectified the problem or can provide a very detailed description as to the actions a mechanic took to rectify it.
Thanks
Old 08-07-2004, 12:41 PM
P11 P11 is offline
ugsrich,
Try taking off the Horn/AirBag/Stereo assembly first. You will need a Torx bit to remove it. Remove the covers and torx head screws just behind the Stereo and A/C controls on both sides. Gently pull towards you the assembly. You can pull it out about 4-6 inches with all the wires attached. Chech the Red wire with the Black plastic tube with a spring on it. Make sure it is pushed in. If it is loose push it into the hole and turn a 1/4 turn till you feel it snap into place.
If this is not your fix you will need to remove the Steering Wheel to further uncover the problem. You will need a couple of special tools (Steering Wheel Puller & Steering Wheel Lock Plate Remover/Compressor).
Jay
