Old 08-06-2004, 05:05 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Is it worh it?
my Tsi has 150,000 miles on the motor,now with this many miles i was not sure if i should go ahead and try building up preformance on this motor with a potential for disaster. Or am i better oof buying a new 4g63 and then building it up?
PS: or is the 4g63 that solid enougf of a motor ,and sould i just worry about the turbo that also has 150,000 miles on it also?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-06-2004, 05:17 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Re: Is it worh it?
it depends on what you are going to do. if you are going to change the internals, bore it, pistons, everithing, you are goin to leave the car just like new, just me It depense if you are thinking on put a bigger turbo, i don't know if it worth it in that way without changing the internals.
In my opinio it worth it.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 08-06-2004, 08:13 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Is it worh it?
Pushing the motor to the kind of power that stock internals are supposed to handle will probably make it wear out fast. If you are asking if the block is still a good candidate for a rebuild with forged internals, then yes it's still good. I wouldn't put anything larger than a 16g on it until you are ready for a new motor.
Old 08-06-2004, 08:23 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Is it worh it?
You'll have quite a while before you'll need to replace major internals. Seals and gaskets are certainly another story, however. I would expect that if you put any performance mods on this car, or drive it hard, that you are going to exacerbate old seals and end up with oil leaks.
I agree with Joe though...even a 150k mile tsi should be able to run 12s or 13s for a good while before you need to rebuild something major. If you know you want to go straight to something bigger than a 16g, you'll want to upgrade the engine itself now.
Old 08-06-2004, 09:18 PM
97_3clipse's Avatar
Re: Is it worh it?
so the hahn super 16G is too big or pushing it?
