Old 08-06-2004, 03:59 PM
dnparadice dnparadice is offline
looking for rear springs
Does any one know where to get some cheep, new, stock/ non lift, rear leaf spring packs for an XJ?
My rear end looks like I’m hauling around some boulders.
-JC
Old 08-07-2004, 12:36 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: looking for rear springs
-JC
The best way to fix leaf springs is take the thing to a spring shop. Look in the yellow pages for a spring shop; most of them work on medium and heavy trucks with leaf springs. They can re-arch the existing springs, add a leaf, or make new ones, usually for the same or less money than it would cost you just to buy new ones (not installed)
They can make sure the Jeep sits at the correct height and is appropriate for the load and ride you want.
If you go out and just buy springs and install them yourself, you are SOL if they are not to your liking.
Also installing leaf springs can be tricky, as sometimes you must pre load them before the bolts line up, a dangerous procedure.
Old 08-07-2004, 05:57 PM
I looked into this and I found a place that will do it but it is 2 hours from where I live. I would rather just get new ones, there has to be somewhere online that you can get stock ones for a reasonable price. Plus I dont like taking my Jeep the the shop for any thing, I like the adventure and knowlage that comes from doing it myself.
-JC
Old 08-07-2004, 06:26 PM
b1gfella b1gfella is offline
I've never bought anything from them, but Quadratec sends thie catalog out and they sell the stock leaf springs and all the related hardware. Both regular and heavy duty...52 and 64 (respectively) dollars for the springs themselves...but if your going to replace them you might as well replace the bushings and any other parts under there that may be worn...have them send you a catalog, if nothing else it is cool to browse through :-)
http://www.quadratec.com
John Harris
http://www.electra225.com
"Problems are just solutions in work clothes"
Old 08-20-2004, 09:01 PM
jroooo jroooo is offline
...and be sure to have plenty of extra bolts lying around since the ones that you have on now will probably sheer off. Spray everything down really good with a heavy duty derusting solution for three to five days before you start. A drill and a tapand dye set but be handy to have too.
Old 08-21-2004, 02:45 PM
is it hard to remove the rear shackle, I was thinking about replacing that since it is cheep. do the bolts that bolt directly into the frame usualy break when you try to remove them sounds like a PITA, i snapped of a few bolts when I instlalled my lift kit.
(it was jus an aal)
