Old 08-06-2004, 03:25 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
steering woes!
well i just got back from an unseceful allgienment I was told the tie rods, ball joints and wheel bearing are shot.
What kinda costs am i looking to fix this *being if thats whats wrong I'm more then happy to hear what else it may be*
Is there a aftermarket way to not only fix but also improve them? I am getting a b16 swap in real soon and the car is drivable would just doing swap help? *being new axles and all that*
I just would like my car back to steering nice.
TIA!
Old 08-06-2004, 03:37 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: steering woes!
tie rods (inner and outter, both sides) = around $150
Ball joints (upper and lower) = around $200
Wheel bearings= around $20
a couple hours to replace.
No aftermarket to improve, nothing to improve really. new axels wont help any.
Old 08-06-2004, 06:59 PM
Ace$nyper's Avatar
Banned
Re: Re: steering woes!
well I can get a huge hook up so parts will be alot cheaper is there anyway a DIYer could do this or should i shop it?
Will getting a camber kit be good idea at this time if so what kind?
thanks again
Old 08-06-2004, 07:44 PM
Forunn Daberator
Re: steering woes!
you can do it all except the ball joints, they are pressed in (I'm assuming you dont have a press). You could take your control arm to a shop and they would press it in for probably less than 10 bucks for both. tie rods are simple, As are wheel bearings. Yeah now would be a great time to invest in a camber kit sence it will all be tore apart down there anyways. Enguls is a good kit, I think it replaces the top ball joint, not 100% on that though. Shure you could look at there website and see (or wait a few minutes and someone else might know.
Old 08-06-2004, 10:38 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: steering woes!
Max, if your upper ball joints are shot, i got a SPC Balljoint replacement camber kit that im looking to sell if your interested. Its adjustable up to 3 degrees. It replaces your stock front upper balljoints.
Pm me if interested
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-07-2004, 01:20 AM
Fewman Fewman is offline
Send a message via AIM to Fewman
You can remove the pressed ball joints. Hammer + torch = easy. Took me about 10 minutes after I got the UCA off. Even did the first one without a torch. After I got it aligned, it has worked perfectly.
