Old 08-06-2004, 02:31 PM
spoolinscboy spoolinscboy is offline
Send a message via AIM to spoolinscboy
Fuel Trim malfunction check engine light
Alright guys my CEL light has been on ever since i have bought the car and i have gotten the code checked and this is what is says. P0170(Fuel Trim Malfunction). There are 3 possibilities on what it can be from what i have been told: 1.O2 sensor, 2. Ignition misfire or vacuum leak, 3. Fuel Injector. These are the symtoms of the car: 1. In the morning when i start up the car, it stumples like it wants to cut off for about 45 seconds, like it idles at around 150rpm's for about 45 seconds. But it idles better after that. It idles around 14 vacuum, which i think is kind of high. But i know it can't be a ignition misfire because it did it when i bought the car, and i swapt out and put in new NGK wires, and NGK 6es plugs and properly gapped them., and it still runs like this. So, this leads me to believe it is a vacuum leak, fuel injector, or 02 sensor. But sense i am installing a downpipe this sat,i dont have to worry about the one after the cat(since i wont have one, so i am gonna get the one before the cat. How can i check for vacuum leaks? Anybody have any ideas on which one of those three it might be? Any help at all would be appreciated.
This saturday i am gonna check for vacuum leaks.
Old 08-06-2004, 03:02 PM
any ideas?
Old 08-06-2004, 04:20 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Fuel Trim malfunction check engine light
I don't know about the vacuum leak thing, but I know when my car tripped the CEL for a fuel trim malfunction, it was my front o2 sensor. I bought a new one and my CEL was gone Good luck
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 07-16-2005, 09:53 AM
boytopak2002's Avatar
boytopak2002 boytopak2002 is offline
i have the same problem on my spyder gst
i changed my o2 sensor and it didn't work i still have it
Old 07-16-2005, 12:07 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
I have the same problem, but from what I have read its most likely the front o2 sensor like what guitarXgeek said. Do you get bad ass milage? I plan on changing mine when I get back!
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 07-16-2005, 02:22 PM
kjewer1 kjewer1 is offline
AF - Advisor
Did you get the codes cleared after changing the O2 sensor? They usually wont go away by themselves (a few of them will). If you cleared it and they came back, I would look into airmetering next. I would log airflow at idle and see what it is.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-16-2005, 04:50 PM
Re: Re: Fuel Trim malfunction check engine light
yeah i clear out the code with my actron 9145 scanner but after 2 days it came back on and man I sure do get a bad gas mileage but yea im going to check my air metring next......peace!
Old 07-16-2005, 05:31 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
vac should be between 17 - 21 during idle. you could have a leak somewhere and/or a bad O2 sensor. go over all vac lines, especially the EGR valve lines. if the EGR valve is not working properly it could affect gas mileage.
Old 07-17-2005, 09:50 PM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
I fixed mine by removing the bulb, lol
Zack
Old 07-18-2005, 12:42 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Way to fix the problem. Great advice too, this guy wants to actually make his car run correctly.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-18-2005, 02:36 AM
gstclips gstclips is offline
Send a message via AIM to gstclips
what a moron
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-19-2005, 04:01 PM
wow, aparently no one has a sense of humor on here.
Zack
