Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 08-06-2004, 11:04 AM
RAZAR RAZAR is offline
Speakers - Front Door
Have 2000 Mirage.
Front speakers blown.
How do I 'get to them' to replace?
What do I have to un-screw, pop-off, or pull to get access to the old blown speakers ?
Thank You !!!
Old 08-06-2004, 06:51 PM
evoryda evoryda is offline
there are a couple of screws youll need to remove. open your door there should be 2 screws covered by caps,that just pulls back, ones where the door meet the dash and the other is near the top on the side where the door meets the hinge. theres one screw, in the door pull (place you pull the door to close it, not bein smart just tryin to explain it good), down in the hole. there is one screw where the handle is, (to open the doors).if its got power windows unplug them once handle is removed, gently tug on the panel be sure not to break it to remove it and take the door opener and just put it through the hole. (and reinstall in reverse, and directions are for each door). you should have it then so good luck and i hoped i helped. later JEREMY
Old 08-07-2004, 02:07 AM
Re: Speakers - Front Door
Thank you !
Hopefully I wont break anything while I try to do this !
Hope you have a great weekend !!!
MATT
