Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 08-06-2004, 09:25 AM
BluesCruiser BluesCruiser is offline
AC leaks water in car
AC on water leaks into car on passanger side ft. floor when I take a left turn..you can hear the water sloshing around on turns..
97 jetta GL 2.0 5 speed..
what the??
Old 08-06-2004, 10:53 PM
boschmann boschmann is offline
Re: AC leaks water in car
It sounds like the drain is clogged. If you go into the engine compartment look behind the engine on the passenger side firewall. Ther is a foil covered piece of insulation covering the firewall. Look fo a u-shaped cutout about where the passenger's feet would be, fold it up and you can see the drain tube. Try to clean it out with a screwdriver and/or compressed air.
Old 08-07-2004, 11:53 AM
shoemy03 shoemy03 is offline
same problem
i have the same problem on my 97 gl automatic. if you fix your problem let me know how you do it so i can fix mine. thanks.
Old 08-11-2004, 09:33 AM
trc5000 trc5000 is offline
I have the same problem. I tried to clean it out, but so far I don't think it worked.
I used a clothes hangar to stick in the horseshoe hole...
I will go try again in a minute.
Old 08-11-2004, 09:50 AM
Ah HA! I found the problem. I just went out and poked around a little.
On mine at least you do NOT need a screwdriver to fix the problem.
Looking from the front of your car, behind the engine there is that foil seal. On mine there were several horseshoe cut outs. The one I needed to find was on the bottom left of the passenger's side (left while looking at the car from the front)
Instead of pushing that little foil flap IN pull it OUT. Underneath it there was a little rubber flap. I had to stick my arm way down in behind the engine to get to it and feel around with my fingers.
If you push the foil in, it will seal off the drain hole even more. I picked mine up with my fingers and probably a liter of water came pouring out.
Old 08-24-2004, 01:36 PM
thanks
TRC5000...thanks pulled the flap and out pours all the water.
Too easy .. so why cold air come winter?? think I shall replug after summer. Drive on
Old 08-24-2004, 05:23 PM
Re: thanks
Cold air in the winter? I wouldn't replug anything with that AC drain. Cold air wont cause a big rush in through a small little hole like that.
Its something else.
Maybe tell a little more of the problem because you are very vauge...
Old 08-25-2004, 08:48 AM
Thumbs up ..
the problem was solved when I pulled the flap
