Old 08-06-2004, 01:21 AM
sLADe781 sLADe781 is offline
Tire Pressure
My sister has a '97 Eclipse GS and I was wondering what the factory tire pressures for it was? Thanks guys.
Old 08-06-2004, 01:33 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Tire Pressure
look on the tire, it should say
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-06-2004, 01:40 AM
Fred95GSX's Avatar
Fred95GSX Fred95GSX is offline
Re: Tire Pressure
Look on the tire? The tire lists the max pressure for the tire, not the factory recomendation on what to inflate it too. Shit, your asking to fuck up the center of your tire and make the car handle and ride like shit with a fully inflated tire.
Look on the inside of the driver's side door to see what the factory says the stock sized tires should be inflated too. The manual also has this info.
Fred
95 Eclipse
04 Quest
Old 08-06-2004, 04:19 AM
george536's Avatar
george536 george536 is offline
Re: Tire Pressure
damn i lost my manual. anyone know?
Old 08-06-2004, 08:15 AM
RSLaser RSLaser is offline
most peeps i know with the 2g say thats its best between 30-32psi.
1991 Plymouth Laser RS
Only sat for a few years....
Old 08-06-2004, 08:29 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
Re: Tire Pressure
If her tire size is 205/55/16, max pressure usually is 45psi, so it's fine to keep it around 30 to 35psi.
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
Old 08-06-2004, 11:16 AM
Fred95GSX's Avatar
Re: Re: Tire Pressure
Did you lose your car too?
Fred
95 Eclipse
04 Quest
Old 08-06-2004, 12:31 PM
RomainDeaMarchi's Avatar
RomainDeaMarchi RomainDeaMarchi is offline
Re: Tire Pressure
What if your tires arent stock..you gotta look to the tire
Old 08-06-2004, 12:40 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Re: Tire Pressure
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-06-2004, 04:46 PM
Fred95GSX's Avatar
That is the max tire pressure for that specific tire. If you inflate to that pressure you will have a very bumpy ride since the tire will not absorb any of the bumps and you will have premature tire wear. Why can you not understand that?
Fred
95 Eclipse
04 Quest
Old 08-06-2004, 05:00 PM
Raz_Kaz Raz_Kaz is offline
Re: Tire Pressure
jebus! It was mentionned earlier, when you open the drivers side door, there is a sticker with the VIN and all other handy info. Some info would be tire pressure (front and back)
And remember kids, when the tire is at the proper pressure, it will look under-inflated
PS....to those wanting to go by the number written on the tire, try it and then post another thread entitiled "rough ride, then bang!"
Old 08-07-2004, 09:23 AM
rodknock rodknock is offline
Send a message via AIM to rodknock
Re: Tire Pressure
Hey the rule of thumb is 32-35 if the drivers door does not specify. Im a tire bitch at pepboys and 90% of the cars we get in are between there.
