Old 08-05-2004, 11:20 PM
Wrx17 Wrx17 is offline
Question Should oil be in spark plugs???
I have a 1990 honda accord ex...4 cylinder. When I remove the spark plug wires from the head, there is oil in the chamber where the spark plugs are? I don't think that's normal....but I may be wrong. If that is a problem....what is the part I need to replace...I see online shops selling spark plug seals...is that what I need. I'd appreciate any help...thanks.
Old 08-05-2004, 11:43 PM
po6834 po6834 is offline
No it is not normal , I had the same problem , you need to go to the dealer and purchase 4 small round gaskets , your gaskets are worn out , if you feel comfortable doing it yourself , you have to remove the valve cover , I think there are 4 acorn nuts securing the cover , remove old gaskets and install new ones , it's probably wise to pickup a new seal for the valve cover as well since you have it off . Also when your done do not over tighten the acorn nuts , you could snap them if your not careful . Good luck
Old 08-06-2004, 12:17 AM
gitter44 gitter44 is offline
Re: Should oil be in spark plugs???
No need to go to the dealer to get the parts , they'll just rape you... Just make a trip to your local auto parts store and buy the whole kit.(valve cover gasket and spark plug gaskets.)
Old 08-06-2004, 01:11 AM
Thanks guys...I'll take care of that.
Old 08-06-2004, 08:19 AM
HONDA_99 HONDA_99 is offline
Re: Re: Should oil be in spark plugs???
not always a case.
set of gaskets for valve cover cost about $27+shipping and about $35+ tax at list price (dealer price).
it includes all rubber gaskets that you'll need.
http://www.hondaautomotiveparts.com/...DER+HEAD+COVER
just shop around and pick whatever you think is best for you.
Old 09-14-2004, 02:37 AM
infiniteracing2003 infiniteracing2003 is offline
Send a message via AIM to infiniteracing2003
i bought the valve cover gasket kit for a friend and installed it all on his car. cake walk. cost me 14 bucks here in SoCal. his car had the same problem, he had no power when he gassed it until like 20MPH then it would start kickin in. a "mechanic" told him his valve's were sticking. HAHAHA dumbshit. 14 bucks and 15 min later his accord ran like new.
Old 09-14-2004, 02:39 AM
P.S. the kit came with valve cover gaskets, the spark plug seals (the main problem) and the washers and bolts that hold the valve cover on.
Old 09-15-2004, 12:28 AM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
OMG THANK YOU!!!! I have to same problem! Everyone I talked to told me that I need to get a new motor or rebuild it! YOU JUST SAVE ME 750 DOLLARS! THANK YOU SO INCREDIBLY MUCH!
I've only just begun...
Old 09-15-2004, 01:47 AM
mpumas mpumas is offline
Dealer sells spark plug seals for about 2.40 ea. If the valve gasket for about 8.00 ea. If you don't need the bolt seals, the dealer is the best bet.
Old 09-20-2004, 06:40 PM
I just changed the seals. Car runs so much better now. I have power from 0-20 now, yay. Thanks guys
Old 09-27-2004, 05:57 PM
undrcroft undrcroft is offline
ok i'm currently changing my gaskets as i have the same leak. the kit comes with two small sets of 4 spkplg tube rings. One set going on the underside of the valve cover, but where do the smaller rings go?
Old 09-27-2004, 09:16 PM
Under the hold down nuts.
Old 09-27-2004, 09:28 PM
nah not the bolt washers, i got those too. There are the 4 flat rings for spkplg tubes that go on the underside of the valve cover but theres 4 more round rings the same diameter, where do these go?
Old 09-28-2004, 01:05 PM
Maybe they are for a different model that uses round gaskets. To reduce the number of part numbers, gasket manufactures sometimes will include gaskets for 2 different but similar models.
