Old 08-05-2004, 10:39 PM
EskimoMarine's Avatar
EskimoMarine EskimoMarine is offline
Send a message via Yahoo to EskimoMarine
Idling problem, 95 GS
I've got a 1995 GS non-turbo, and I've been having an idling problem. Sometimes the car will just quit when at idle. For the most part it will be just when I'm waitin for someone while chillin and listening to music. Every now and then, it'll die when I'm in neutral at a light.
The car idles at about 1,000 RPM, I don't know if this is low or not, but somtimes I notice that the rpms will drop about 100-150ish.
Before I realized there was a problem I was in a park listenin to the system, car died and ran the battery down pretty good, if I hadn't noticed the car wasn't runnin I may have ran into some problems gettin back home.
Any ideas?
Old 08-06-2004, 12:45 AM
HotCrew's Avatar
HotCrew HotCrew is offline
Send a message via AIM to HotCrew
Re: Idling problem, 95 GS
Well the idle should be at about 700 to 800 really...but do you have anything on it other than just a stock car?
Check out my site
After Night Groove Team Site
RS-T Build Up Site
http://www.angelfire.com/pro2/rst
Old 08-06-2004, 02:53 AM
Stock
To my knowledge, the car is stock. I haven't done anything to it, but I just bought it a week ago, so, I don't know what the problem is. A buddy of mine drove it when it stalled once at a light, he said that the fuel injectors might be dirty? How would I fix that?
Old 08-06-2004, 08:41 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Have you replaced the fuel filter lately??? As far as cleaning the injectors, you can go to autozone or some place like that and get fuel system/fuel injector cleaner. It is only a couple of dollars and you add it to your gas tank right before you fill up. I do it with every oil change.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-06-2004, 10:36 AM
96tuner 96tuner is offline
Send a message via ICQ to 96tuner
my first guess would be the tps. (throttle position sensor) My guess is that like my 96 gs it has some miles on it and if it hasnt been replaced yet that could be the trouble... Think it cost me $50 for the part....
Old 08-06-2004, 02:21 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
isc
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-06-2004, 02:40 PM
GSTRacerNVUS GSTRacerNVUS is offline
Yea, but, wouldn't the check engine light come on if the tps was bad? Mine did anyway...
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 08-06-2004, 05:22 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
As for a fuel injector cleaner I suggest LUCAS...
WWW.LucasOil.com
I was getting about 18-20 MPG and used this 3 times every other tank... now i'm getting about 22-24 MPG... The bottle says.."cleans and lubricates carburetors, injectors and valve seats" I've tried some other stuff before this but didn't notice any change really...
As for the idle problem you might want to check your throttle body plate... I had some carbon build up causing my idle to be lower than normal when at a stop light... I used an air intake cleaner and a tooth brush and have had no trouble since...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
