Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 08-05-2004, 10:33 PM
Kenneth Fellers Kenneth Fellers is offline
Wink 1990 Laser
Just signed on with a problem.....my 1990 Plymouth Lase overheated. I replaced a bad heater hose and the thermostat. Still overheats and the radiator fans don't come on even when I engage the A/C. Any one else ever had this problem. Solution? Would be appreciated. Thanks
Old 08-07-2004, 12:01 AM
eightcylS10 eightcylS10 is offline
Re: 1990 Laser
its got to be a relay of some sort
Old 08-09-2004, 04:30 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 1990 Laser
Does it overheat when travelling down the road?
If it just overheats when it's sitting, the fan motors might be burnt out. Might also be a relay like mentioned earlier...
My Mopars
Old 08-10-2004, 10:27 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: 1990 Laser
Check to make sure the fans are stil plugged in, the connector is on the pass side at the bottom of the radiator.
Also, check your fuses as mentioned.
Kris
2012 Genesis Coupe 2.0t
Old 08-19-2004, 01:18 PM
OnefistedPirate OnefistedPirate is offline
Banned
Re: 1990 Laser
If the plugs check out and the fuses/relay then bust out the volt meter and try to get a reading off the fan plug on the pass side, then the drivers side. There are two - and two + wires. 2 speeds. The white with colored stripe (should be the color) will be your + wire.
