Old 08-05-2004, 08:55 PM
Str8in Str8in is offline
Banned
Send a message via AIM to Str8in
Si problems
Ok my friend has a 91 crx si. It all started when his car shut off out of no where the problem was his timeing wasnt set right and the bolt for the cam gear was loose and the belt had tightened up n was against the head.......ok that was fixed now like the nex day he went through a puddel of watter and his car shut off tested it for spark and there was none so he changed the distributor.....low spark and smoke coming out of the intake. What i think is wrong is that he bent his valves. What do you guys think could be wrong with it?
Old 08-06-2004, 01:55 AM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: Si problems
water water water in the block and since it splashed into the bay that much to fry the distributor, check the other components under the hood (everything= wiring, fuses....). your luky the motor didnt hydro lock.
