Old 08-05-2004, 08:51 PM
MachFive MachFive is offline
98 V-6 Accord Intermittent Startup Problem
Hello.
My car has had intermittent startup problems for about six months now. The car will crank, but not turn over. The length of time it will not start is completely random. Sometimes it will start within five minutes. Other times several hours. I have gone four to six weeks without it happening once and then it will happen five days in a row. It will happen at any point in the day or night, cold or hot, rain or snow. I took it to a Honda dealer once, they said it was fixed, and two days later it happened again. That was about 2 months ago. I am hesitant to take it again. Any help would be much appreciated.
Thanks,
M
P.S. I know little about cars. Change oil, brakes, and tires. That's about it.
Old 08-06-2004, 06:52 AM
HONDA_99 HONDA_99 is offline
Re: 98 V-6 Accord Intermittent Startup Problem
Did you get your ignition switch replaced? Honda recalled 6gen V6 models for faulty ignition switches.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
Old 08-06-2004, 09:17 AM
Replaced.
M
Old 08-06-2004, 10:05 AM
if your ingition switch was replaced, i think you might have problems with main relay.
here is where you can read up on main relay issues and fixes:
http://www.v6performance.net/forums/...ad.php?t=25691
Old 08-30-2004, 01:55 AM
phantastic1 phantastic1 is offline
like honda 99 said....it may be your main relay. but check your spark plugs to see if they are bad.
Old 09-03-2004, 12:19 PM
Braceman Braceman is offline
Smile Kudos to Plumaccordcoupe and automotive forum
This is the first time I have every used a forum. I was ready to sell my 98 Accord Coupe because I had this starting problem which only occurred after the car sat in the sun for 2-3 hours. It was like it was out of gas. The Dealer couldn't figure it out but he sure made a lot of money off of me. Finally a friend told me to try the web. Thanks to Mr. Plumaccordcoupe his accurate and detailed advice helped me solve the problem. I told the mechanic to change the main relay and problem was solved. Thank Automotive Forums
Old 09-05-2004, 08:05 PM
Accord_99 Accord_99 is offline
Send a message via AIM to Accord_99
It is most likely your main relay. I just had mine replaced because of the same problem...the part is like $30 bucks and then labor puts you little over 100 bucks.
[img]Cocuments and SettingsJames IerardiMy DocumentsMy PicturesCarsRoll1[/img]
Old 09-11-2004, 01:08 AM
sam_25 sam_25 is offline
[quote=MachFive]Hello.
Did you ever find out what the problem was in your accord. i seem to be having the same problem with my 98 accord. please let me know if you did thanks
