Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 08-05-2004, 05:04 PM
Aneche Aneche is offline
Send a message via MSN to Aneche
Light trucks any good?
I've got a '94 Sonoma.
I've won quite a few races with it, but really, are pickups any good?
Old 08-05-2004, 05:42 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Re: Light trucks any good?
They can be. I've seen more than one 8-second truck at the LVMS drag strip. And there are some small Nissan trucks that are pretty sick at drifting.
Old 08-05-2004, 05:54 PM
micro04102 micro04102 is offline
small trucks def can be. i've seen a blazer that was 7-8 sec's. throw a superchanger in and you will fly. make sure to lower it for better control.
Old 08-05-2004, 05:57 PM
Ah cool.
supercharger......nice. I was thinking of a better exhaust system first tho.
Old 08-05-2004, 06:54 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
personally i think you're better off working on a car, but i've seen a 10 second plumber's van, so if you want to it can definitely be done.
just remember...google is your best friend when looking for parts.
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 08-05-2004, 07:47 PM
landyacht's Avatar
landyacht landyacht is offline
Sure trucks can be great...the Lightning is a good example, a smaller truck is the Dakota R/T that can hustle.
Lots of potential with those small trucks because they're rear drive and light. Just make sure you work on the suspension (etc) aswell before you do anything because a truck is still a truck, you don't wanna have it super strong and have no grip.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 08-05-2004, 08:20 PM
RedLightning's Avatar
RedLightning RedLightning is offline
or that typhoon or whatever, and the s-10 eXtreme, i heard that they are nice, but i prefer the lightning.
1993 F-150 Lightning
Mods-March UD pullies, Ltngdrvr CAI, Flowmasters, E-fans, and Eibach / Bell-Tech Drop Kit in the garage.
http://www.cardomain.com/ride/2149061/1
Originally Posted by KustmAce
Real emo kids kill themselves.
Old 08-05-2004, 09:34 PM
DeViL DeViL is offline
I gotta admit the 4.3L is not an easy engine to upgrade. Not much of a market out there for it. The high powered camshafts aren't emissions legal, I think you can only bore and stroke it out to a 4.5L and the gains aren't worth the money, neither is modifying the heads (there are no aluminum heads available). Headers will make a noticable difference though.
You are probably much better off dropping a 350 V8 if you are dead serious about drag racing. But alas, I'm messing with the V6 anyways. Best bet if you stick with the V6, a little better cam, a supercharger + intercooler, headers + exhaust, traction bars, 4.10 or 4.56 gears, and play around with the computer a bit with the Hypertech Power Programmer. You have a 94 so I don't know what exactly is available for your Sonoma, most aftermarket stuff out there is meant for 96 and up, so its probably just going to make it even harder for you.
'01 S-10 Xtreme - Supercharged 4.3L V6, 10 psi.
'88 Firebird Trans Am GTA - 5.7L V8, 4spd auto.
'06 GTO Brazen Orange Metallic - 6.0L V8, 6spd (the new toy/daily driver)
Old 08-05-2004, 10:55 PM
Ah, cool.
I have a friend who works in an aftermarket shop so he'll prolly be able to find the stuff I can't on google....
So from what I'm seeing, if I make any engine mods, I need to lower it. S'cool.
Old 08-06-2004, 01:18 AM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
The GMC Cyclone was a very fast truck (there was a Typhoon as well, it was basically a GMC Jimmy). The Cyclone was an AWD S-15 (same thign as a Sonoma, just called S-15 back then I think) that had a turboed 4.3 taht made 295 hp--they were very fast.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 08-08-2004, 06:22 PM
fearsomefairmont fearsomefairmont is offline
Trucks are excellent drag machines. They are close to the utter minimum of weight possible. Just take an old ranger or S-10 and drop a honkin V8 in, mess with suspension to get good weight transfer, and it will be REALLY fast. It is all about power to weight, and they make good sleepers too.
Old 08-08-2004, 06:47 PM
you have to do it just right other ways all youll get is wheal spin.
Old 08-08-2004, 07:22 PM
Explain doing it right I don't follow you.
Old 08-09-2004, 10:29 AM
To explain, these trucks are about the right size for a small block ford or chevy. They came stock with a 4.3 V6, which is essentially a 350 chevy missing 2 cylinders. So, you take the trans and motor of your choice and use a front plate mount for the motor. It will even fit almost under the hood. As for wheel spin, the trick is to use a very compliant rear suspension so as much weight as possible is transferred to the rear tires. Definitely use coilovers or some sort of 4 link setup. Or, launch on AWD, as lingenfelter's twin turbo S-10 did. That was a wild ride - twin turbos, 19 mpg, and a solid 9 secs street ride. Anything is possible!
Old 08-09-2004, 04:40 PM
Re: Re: Light trucks any good?
well i cant really explain it, becuase i dont know to much about it, but i was reading a review of the srt-10 ram, and they had to do alot of special stuff to it so it did not just do burn outs, perhaps i worded it wrong.
