Old 08-05-2004, 04:18 PM
americanmuscleman americanmuscleman is offline
Send a message via AIM to americanmuscleman
Smile awsome paint remover
ok i went with my brother to pep boys and i was gonna buy some castrol super clean because i wanted to test out if it works on an old beat model. they were out of castrol so i got this stuff called purple power. got 2 gallons for 6 bucks. i put the model in this for an hour and almost all the paint was off. this stuff works great! it took off a layer of silver, blue, abotu 4 layers of red, and a couple coats of primer. it is cheaper and it works just as good so i recomend picking some up
Old 08-05-2004, 04:26 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Exactly the same product, sold under a different name. But it does work great- it's what I use!
PHOTOBUCKET SUCKS
Old 08-05-2004, 05:58 PM
trikkedoutsupra trikkedoutsupra is offline
Send a message via AIM to trikkedoutsupra
Re: awsome paint remover
I Use Easy Off Oven Cleaner And Put The Model In A Bag And Let It Sit Over Night Then In The Morn I Run Water Over It And Scrub With The Rough Side Of A Sponge
My Beautiful Truck After It Burnt Up
Damn
Old 08-05-2004, 06:18 PM
Jaymes's Avatar
Jaymes Jaymes is offline
would 99% alcohol work as well with tough ones?
they come in a plastic case..hmm
Old 08-05-2004, 07:04 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
i just got some brake fluid and it works pretty good. but it eat away at the putty aswell. do all these other products do that?
http://www.automotiveforums.com/vbul...d.php?t=620111
"Look as far as the eye can see, go there, then look farther."
Old 08-05-2004, 07:14 PM
willster127's Avatar
willster127 willster127 is offline
I'm gutted now, I literally just bought a gallon of castrol for 10 bucks!!!!!!! I saw the purple power there too!
Anyway, do you guys use this stuff neat or dilute it down with water?? I don't want to damage the plastic
The Willster....
Old 08-05-2004, 07:59 PM
i used the purple power straight with no water and it didnt damage the plastic at all. the only paint that it didnt take off was the paint in the panel lines
Old 08-06-2004, 01:15 AM
Mainomega Mainomega is offline
Ammonia does it in a few mins. 91% IPO could work but ammonia is cheaper
Got Something Good ? E-mail me
Old 08-07-2004, 06:58 PM
Obituary Obituary is offline
a few questions:
1. once you use purple power, what do you do with the liquid that you used? drain it? or can I use it again? (I have 2 models that I wanna remove old paint off)
2. after the model has been soaked by purple power for a day, how did you clean the old paint?
3. does purple power smell strong? (sorry..kinda newbie question, but never dealt with such product before)
Old 08-08-2004, 12:56 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
I wouldn't water down CSC (or purple power, as it's the same thing). I've been using the same CSC for the past 2 years now and it's still working fine after plenty of strippings. Brake fluid doesn't seem to last as long though. Also, CSC will not strip lacquer paints. No Tamiya TS Sprays, Duplicolor, Plasticote...none of those.
Old 08-08-2004, 08:49 AM
Then How do you dispose CSC after usage?
If CSC does not strip the ones that you described, then what DOES it strip?
I Do want to strip Tamiya TS Sprays. In this case, what would you recommend to use to strip the paint?
Old 08-08-2004, 11:42 AM
minniebanister minniebanister is offline
People keep posting about using some wonderful stripper but they don't say what type of paint they are stripping. Surely it makes a big difference? For example, I use Windex to strip acrylic paint but I think it would be useless on enamel (would make enamel paint really clean though).
Old 08-08-2004, 12:24 PM
MidMazar's Avatar
MidMazar MidMazar is offline
So what strips lacquer paint? Like dupicolor?
Old 08-08-2004, 12:35 PM
tonioseven's Avatar
I have used 91% Isopropyl Alcohol to strip Tamiya sprays and Duplicolor paints. I haven't tried it yet on Plasti Kote paints.
Old 08-08-2004, 12:59 PM
obituary, after i used my purple power i stuck it in a coffee can then put it in a bag and in the trash can but you could pour it out cause its not harmful. to clean the paint off i just rinsed it off in the sink and scrubbed it with an old toothbrush.and uhh i guess it dont smell that strong cause i only smelled it when i was right near it. everyone else mine took of primer and 6 coats of enamel.
