Old 08-05-2004, 03:59 PM
lilski lilski is offline
Question Weird new clutch slipping problem
98 Eclipse GST. Clutch started slipping so I had it replaced. The master and slave clutch cylinders blew after the new clutch was installed so they were replaced. Ever since the clutch hasn't worked or felt right. The weird part is that when the car is cold, the clutch pedal feels right and works right. Once the car heats up though, the clutch pedal increases in pressure to the point where the clutch starts slipping like I'm pushing the pedal in slightly. Two shops, one dealership later...no one can fix it. I've gone through three new clutches and four sets of master and slave cylinders thinking it was faulty parts; no luck. Any ideas would be greatly appreciated.
Old 08-05-2004, 08:09 PM
10.5sec92AWDTALON 10.5sec92AWDTALON is offline
Re: Weird new clutch slipping problem
Sounds like you might have crankwalk.
Old 08-05-2004, 08:19 PM
rodknock rodknock is offline
Send a message via AIM to rodknock
Thats exactly what i was thinking. Thats usually the first sign. Clutch problems.
Old 08-05-2004, 11:57 PM
The dealership mentioned something about crank lock, but that doesn't make sense to me regarding the problem gets worse when the engine heats up. You'd think crank lock would cause problems at all temperatures.
Old 08-06-2004, 12:10 AM
After reviewing some docs on crankwalk, it definitely sounds like what I'm experiencing. Thanks for the tip.
