Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-05-2004, 03:43 PM
crabby760 crabby760 is offline
adjusting points for a b16a
i just bought a fuel pressure regulator i also have cam gears on the stock b16 cams
i was curious if anyone has dyno tuned there b16 with basic mods i was curious what are the cam gears set at and what is your fuel pressure regulator set to also where is ur distributor moved to wat point?
if anyone can help this would be great i'd rather try and tune it my self rather than pay 80 bux an hr for them to do the same thing
Old 08-05-2004, 04:01 PM
96Civ's Avatar
96Civ 96Civ is offline
Re: adjusting points for a b16a
You cannot adjust points because it doesn't have any! Your computer does all the adjustments.
Old 08-05-2004, 04:23 PM
what yes u can
u can adjust the fuel pressure regulator to a certain point
u can adjust the cam gears to a certain point each one
and you can adjust your distributor to a certain point...
i wanted to know if anyone with a b16 has gotten there car dynoed and if so what points is all that set to!
Old 08-05-2004, 04:28 PM
96Civ's Avatar
I don't think we are talking about the same thing here. A "Point" is an actual part in the distributer in much older cars. You had me confused there with your simple lingo.
Old 08-06-2004, 04:08 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
hard to tell what exactly you should set the cams and fpr too because every motor responds different to changes, one might like adv or might like rtd, so its hard to tell you to set it exactly to this.
Team Lonely Drivers
Old 08-06-2004, 01:43 PM
well if anyone has a b16 with those similar mods and has had it dynoed just put what your fpr/camgears/distributor... are adjusted to then let me know what hp number's u got thanks
Old 08-08-2004, 09:08 PM
if anyone can give me any adjustments anything will help me
