Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-05-2004, 02:05 PM
Birdman11 Birdman11 is offline
Brake Light Problem
Has anyone ever experienced an electrical problem where the Left tail light goes out when the brakes are applied and the head lights are on? I've changed the bulb...no luck! Any thoughts?
Old 08-05-2004, 10:45 PM
JDPascal JDPascal is offline
Re: Brake Light Problem
check the other bulbs for the park lites etc. and the highmount brake lite bulbs.
sometimes when a bulb burns out there is a kind of feed back voltage where 12v is applied to both sides of the bulb and causes it to not lite. alternating signal lites on the corners of the vehicle are planned examples of this but unplanned happenings can puzzle the heck out of you.
JD
PS - let us know what you find. these odd problems should be archived or something so we can refer back to them.
Old 08-06-2004, 11:38 AM
backpacker2004 backpacker2004 is offline
Unhappy grand cherokee brake lights
I have the same exact problem with the left brake/tail light turning off when brakes are applied while the lights are on, in any mode. Have you fixed this yet? And the brake lights work when the car does not have its lights on. weird, eh? -trav
Old 08-11-2004, 02:44 PM
cbr92901 cbr92901 is offline
the problem I have is that when the brakes are applied, both turn signals also light up. When I use left turn signal, the message board inside car says turn signal problem. I've checked all bulbs and fuses. Any ideas?
Old 08-11-2004, 04:55 PM
camodiak camodiak is offline
i also have this problem, mine happens when i drive thru a puddle of water, something up there gets wet and makes it do it???
also does it when im hualing my quad up north to go riding? whenever i press the brakes it goes off saying rear light failure, but i can't seem to find the problem, unhook trailer, start back up and no problems????tim
Old 08-11-2004, 05:25 PM
Here's the deal...I found out that this is a known problem. The only way to fix it is to replace the tail light assembly. OEM part is about $165.00. You can get after market parts for about $60-65. I just received mine and installed the new assembly. Works as advertised. Hope this helps.
